Post reset problem
I reinstalled nextcloud (version 31) on my raspberry pi 5, then I performed restoring data (database restored via phpmyadmin) data folder restored with rsync -Aax data command etc etc, I use php 8.4 latest version of raspberry pi os.
when I go to log in via web I receive:
Internal Server Error
The server was unable to complete your request.
If this happens again, please send the following technical details to the server administrator.
Additional details are available in the server log.
Technical Details
Remote Address: 192.168.1.13
Request ID: TJKqJj0gsUj88LBraLH0
Advice?
You need to do as it suggests: check your Nextcloud log.
See https://docs.nextcloud.com
I do hope you also included your config/ folder. See: Restoring backup in the Admin Manual.
I copied the config folder, now everything works, thanks
