Post-Installation Error: PHP Settings Incorrectly Applied?
Apologies for any incomplete submission.
  • Ran the curl installer for NextcloudPi on RPi4 that is running Bookworm
  • Created two “user” accounts
  • Was able to make entries for Tasks for both users
  • Tried to do more… install apps but not successful
  • Saw the Updater notice and tried it. That is when I noticed the error message to check the logs; over 200+ similar messages.
  • Tried RTM to see if I made any mistakes. If I have, then it was done out of ignorance.
Hope I can recover from this! :grinning:
  • Nextcloud Server version:
    • 30.0.1
    • Debian GNU/Linux 12 (bookworm)
    • Server version: Apache/2.4.62 (Debian)
    • Server built: 2024-10-04T15:21:08
    • replace me
    • PHP 8.3.14 (cli) (built: Nov 25 2024 18:23:27) (NTS)
    • Zend Engine v4.3.14
    • Zend OPcache v8.3.14
    • NCP
  • Installation method (e.g. AIO, NCP, Bare Metal/Archive, etc.)
  • Are you using Cloudflare, mod_security, or similar? (Yes / No)
Error while checking the temporary PHP path - it was not properly set to a directory. Returned value: /opt/ncdata/data/tmp
message “CORS requires basic auth”
Don’t know whether the two are related, sorry, I’m just a newbie.
  1. Select NextcloudPi button on toolbar at the top of the Dashboard page
The following record is repeated continously in the log file:
Level: Error
Application: PHP
Message:
Trying to access array offset on false at /var/www/nextcloud/apps/settings/lib/SetupChecks/CheckServerResponseTrait.php#97
Level: Error
Application: PHP
Message:
fread(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#55
PASTE
PASTE HERE
PASTE HERE
After much searching, the “CORS REQUIRES BASIC AUTH” error when you click the nextcloudpi button appears to be a bug. The workaround is to not use that button. Hopefully they fix it someday or at least remove the button.
I am going through and replying to all these threads with a message pointing to this bug report so people will have an answer.
