Nextcloud version: 18.0.3.0
Operating system and version: Debian 10
Apache or nginx version: Apache/2.4.38
PHP version: 7.3.13
Website is completely fine at Port 80 & 443. But I also need access via CURL. My other instances on the same Server and Ports are working fine on CURL. I just get the message with CURL:
Failed to connect to cloud.barner.online:443 : Connection refused
I already checked the Virtual Hosts but nothing unusual there.
Nothing about this topic.
'instanceid' => '********',
'passwordsalt' => '**********',
'secret' => '********',
0 => 'cloud.barner.online',
'datadirectory' => '/mnt/data/nextcloud/',
'version' => '18.0.3.0',
'filelocking.enabled' => false,
'overwrite.cli.url' => 'http://cloud.barner.online',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => '********',
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'noreply',
'mail_domain' => 'barner.online',
'mail_smtphost' => 'mail.barner.online',
'mail_smtpport' => '465',
'skeletondirectory' => '',
'force_language' => 'de',
'knowledgebaseenabled' => false,
'theme' => '',
'loglevel' => 2,
'app_install_overwrite' =>
0 => 'rainloop',
1 => 'loginviapost',
'mail_smtpauth' => 1,
'mail_smtpname' => 'noreply@barner.online',
'mail_smtppassword' => '********',
'mail_smtpsecure' => 'ssl',
Just other problems from other Threads.
Virtualhost (443/SSL)
<IfModule mod_ssl.c>
<VirtualHost 173.212.231.239:443>
ServerAdmin malte@barner.online
ServerName cloud.barner.online
ServerAlias cloud.barner.online
DocumentRoot /var/www/barneronline/nextcloud
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
SSLCertificateFile /etc/letsencrypt/live/cloud.barner.online/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/cloud.barner.online/privkey.pem
</VirtualHost>
</IfModule>
Virutalhost (80)
<VirtualHost 173.212.231.239:80>
ServerAdmin localserver@localhost
RewriteEngine on
RewriteCond %{SERVER_NAME} =cloud.barner.online
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
