Please restart AppOrder project
please restart that simple and light project :pray:
Hey, there is good news. There is a solution worked on at the moment. You will have to be a bit patient.
Apporder was fully deprecated back in nc25
fyi: PSA: AppOrder is no longer maintained or usable as of Nextcloud 25
Just for cross reference: Please restart AppOrder project - #2 by christianlupus
I am going to leave here as I cannot provide any input, I guess.
Should that be standard for every user? You can set up a standard apps argument in the config.php, see the documentation for further instructions.
According to their github issue it will be a user only option and not configurable by the admin.
" * This is a user-setting only, no admin setting" ↔️ Make app order configurable · Issue #4917 · nextcloud/server · GitHub
