Hello everyone!
Can you please help me with restore that i’ve been battling for last 5 days I have a NC server that has been running pretty good for 3-4 years, no major issues. I need to migrate my NC instance off of it.
Currently I’m running in on Ubuntu 20.04 Server and nginx. NC version upgraded to 25.02. New server is Rocky 9 with apache (hope this is not a problem). On new server I installed 25.02 and went through initial setup, no issues.
I followed the official latest nc admin guide for migrating to new server, https://docs.nextcloud.com/server/latest/admin_manual/maintenance/migrating.html
I put both instances into maintenance mode and created mariadb backup and resync-ed user data over to new server.
I run restore of the db using
sudo mysql -h localhost -u ncadmin -p -e "DROP DATABASE nextcloud_db"
sudo mysql -h localhost -u ncadmin -p -e "CREATE DATABASE nextcloud_db"
sudo mysql -h localhost -uroot -p -e "GRANT ALL PRIVILEGES on nextcloud_db.* to ncadmin@localhost"
sudo mysql -h localhost -u ncadmin -p nextcloud_db < /tmp/nextcloud-sqlbkp_20221224.bak
Also i ran: sudo -u apache php /var/www/html/nextcloud/occ maintenance:data-fingerprint
i do not see an error after restore, but when i try to exit maintenance mode i get following errors. Its obviously permission issue after restore ( i think).
Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user 'ncadmin'@'localhost' (using password: YES) in /var/www/html/nextcloud/lib/private/DB/Connection.php:139
Stack trace:
#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1519): OC\DB\Connection->connect()
#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1041): Doctrine\DBAL\Connection->getWrappedConnection()
#2 /var/www/html/nextcloud/lib/private/DB/Connection.php(261): Doctrine\DBAL\Connection->executeQuery()
#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(345): OC\DB\Connection->executeQuery()
#4 /var/www/html/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(281): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/html/nextcloud/lib/private/AppConfig.php(415): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/html/nextcloud/lib/private/AppConfig.php(180): OC\AppConfig->loadConfigValues()
#7 /var/www/html/nextcloud/lib/private/AppConfig.php(371): OC\AppConfig->getApps()
#8 /var/www/html/nextcloud/lib/private/legacy/OC_App.php(965): OC\AppConfig->getValues()
#9 /var/www/html/nextcloud/lib/private/Server.php(725): OC_App::getAppVersions()
#10 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\Server->OC\{closure}()
#11 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#12 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet()
#13 /var/www/html/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#14 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query()
#15 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(184): OC\AppFramework\Utility\SimpleContainer->get()
#16 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#17 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#18 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet()
#19 /var/www/html/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#20 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query()
#21 /var/www/html/nextcloud/lib/private/Server.php(1119): OC\AppFramework\Utility\SimpleContainer->get()
#22 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\Server->OC\{closure}()
#23 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#24 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet()
#25 /var/www/html/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#26 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query()
#27 /var/www/html/nextcloud/lib/private/Server.php(2070): OC\AppFramework\Utility\SimpleContainer->get()
#28 /var/www/html/nextcloud/lib/private/Files/View.php(117): OC\Server->getLockingProvider()
#29 /var/www/html/nextcloud/lib/private/Server.php(462): OC\Files\View->__construct()
#30 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\Server->OC\{closure}()
#31 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#32 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet()
#33 /var/www/html/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#34 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query()
#35 /var/www/html/nextcloud/lib/private/Server.php(1472): OC\AppFramework\Utility\SimpleContainer->get()
#36 /var/www/html/nextcloud/lib/base.php(617): OC\Server->boot()
#37 /var/www/html/nextcloud/lib/base.php(1144): OC::init()
#38 /var/www/html/nextcloud/console.php(48): require_once('...')
#39 /var/www/html/nextcloud/occ(11): require_once('...')
#40 {main}[ncadmin@nextcloud ~]$
Can you please help with what i am doing wrong and resolve this
