Can someone take a look at my setup. I cannot find any error messages but I cannot connect to Nextcloud. I am on a Johnsbo n2, Intel i7-4770, 8b ram, Ubuntu 22.04, connecting to my subdomain, with Nextcloud installed on external raid 1 setup.
sudo docker-compose logs nextcloud
Attaching to nextcloud-aio-mastercontainer
nextcloud-aio-mastercontainer | Initial startup of Nextcloud All-in-One complete!
nextcloud-aio-mastercontainer | You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
nextcloud-aio-mastercontainer | E.g. https://internal.ip.of.this.server:8080
nextcloud-aio-mastercontainer | If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
nextcloud-aio-mastercontainer | https://your-domain-that-points-to-this-server.tld:8443
nextcloud-aio-mastercontainer | {“level”:“info”,“ts”:1711399235.6254015,“msg”:“using provided configuration”,“config_file”:“/Caddyfile”,“config_adapter”:“”}
nextcloud-aio-mastercontainer | [Mon Mar 25 20:40:35.639886 2024] [mpm_event:notice] [pid 128:tid 133297569757960] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured – resuming normal operations
nextcloud-aio-mastercontainer | [Mon Mar 25 20:40:35.639933 2024] [core:notice] [pid 128:tid 133297569757960] AH00094: Command line: ‘httpd -D FOREGROUND’
nextcloud-aio-mastercontainer | [25-Mar-2024 20:40:35] NOTICE: fpm is running, pid 138
nextcloud-aio-mastercontainer | [25-Mar-2024 20:40:35] NOTICE: ready to handle connections
nextcloud-aio-mastercontainer | {“level”:“info”,“ts”:1711398717.8487136,“msg”:“using provided configuration”,“config_file”:“/Caddyfile”,“config_adapter”:“”}
nextcloud-aio-mastercontainer | [Mon Mar 25 20:31:57.853823 2024] [mpm_event:notice] [pid 126:tid 129771792431880] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured – resuming normal operations
nextcloud-aio-mastercontainer | [Mon Mar 25 20:31:57.853861 2024] [core:notice] [pid 126:tid 129771792431880] AH00094: Command line: ‘httpd -D FOREGROUND’
nextcloud-aio-mastercontainer | [25-Mar-2024 20:31:57] NOTICE: fpm is running, pid 137
nextcloud-aio-mastercontainer | [25-Mar-2024 20:31:57] NOTICE: ready to handle connections
Docker-compose.yml
version: ‘3.8’
services:
nextcloud:
init: true
restart: always
# Assuming you’re using a reverse proxy, remove exposed ports
ports:
- “80:80”
# - “444:443” # Update port to avoid conflict (adjust if needed)
# - “3478:3478”
volumes:
- “/mnt/raid1:/mnt/data”
environment:
# Add any environment variables needed by Nextcloud AIO here
# For example:
NEXTCLOUD_ADMIN_USER: xxxx #commented out
NEXTCLOUD_ADMIN_PASSWORD: xxxxx
New Apache reverse proxy service (assuming you have a separate service for this)
… (configuration for your reverse proxy service)
volumes:
Apache.conf
Basic server configuration (Listen on port 8080)
Listen 8080
<VirtualHost *:8080>
Replace with your domain name (optional)
ServerName keemosavy.duckdns.org
Enable mod_proxy and related modules if not already enabled
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_http_module modules/mod_proxy_http.so
LoadModule proxy_wstunnel_module modules/mod_proxy_wstunnel.so
Preserve host header for Nextcloud
ProxyPreserveHost On
Disable proxy requests for this virtual host
ProxyRequests Off
Forward all traffic to Nextcloud AIO on port 80
ProxyPass http://nextcloud:80/ ProxyPassReverse / http://nextcloud/HTTPS configuration with reverse proxy for Nextcloud
Listen 4433 ssl
# Replace with your domain name (optional) ServerName keemosavy.duckdns.org# Configure SSL using your certificates (replace paths)
SSLEngine on
SSLCertificateFile /path/to/your/server.crt
SSLCertificateKeyFile /path/to/your/server.key
# Enable mod_proxy and related modules (already loaded above)
# Preserve host header for Nextcloud
# Disable proxy requests for this virtual host
ProxyRequests Off
