Pico can not work
[index] Error: Exception: Call to undefined method ParsedownExtra::textElements() at <>
  1. /ncdata/lib/private/AppFramework/App.php line 126
    OC\AppFramework\Http\Dispatcher->dispatch(OCA\CMSPico\Controller\PicoController {}, “getPage”)
  2. /ncdata/lib/private/AppFramework/Routing/RouteActionHandler.php line 47
    OC\AppFramework\App::main(“OCA\CMSPico\C … r”, “getPage”, OC\AppFramework\ … {}, {page: “”,site: … "})
  3. <>
    OC\AppFramework\Routing\RouteActionHandler->__invoke({page: “”,site: … "})
  4. /ncdata/lib/private/Route/Router.php line 297
    undefinedundefinedcall_user_func(OC\AppFramework\ … {}, {page: “”,site: … "})
  5. /ncdata/lib/base.php line 1000
    OC\Route\Router->match("/apps/cms_pico/pico/itindex")
  6. /ncdata/index.php line 42
    OC::handleRequest()
GET /index.php/apps/cms_pico/pico/itindex
mysql nginx config
upstream php-handler {
server 127.0.0.1:9000;
#server unix:/var/run/php/php7.2-fpm.sock;
server {
listen 80;
listen [::]:80;
server_name doc.xxx.com;
# enforce https
return 301 https://$server_name:443$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /nc/nginx/server.crt;
ssl_certificate_key /nc/nginx/server.key;
# Use Mozilla’s guidelines for SSL/TLS settings
# https://mozilla.github.io/server-side-tls/ssl-config-generator/
# NOTE: some settings below might be redundant
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
# could take several months.
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
root /ncdata;
location = /robots.txt {
    allow all;
    log_not_found off;
    access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
 rewrite ^/sites/(.*)$ https://doc.xxx.com/index.php/apps/cms_pico/pico/$1 last;
# The following rule is only needed for the Social app.
#rewrite ^/.well-known/webfinger /public.php?service=webfinger last;
  return 301 $scheme://$host:$server_port/remote.php/dav;
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
#pagespeed off;
location / {
    rewrite ^ /index.php;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
    deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
    deny all;
location ~ ^\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+)\.php(?:$|\/) {
    fastcgi_split_path_info ^(.+?\.php)(\/.*|)$;
    set $path_info $fastcgi_path_info;
    include fastcgi_params;
    fastcgi_param PATH_INFO $path_info;
    fastcgi_param HTTPS on;
    # Avoid sending the security headers twice
    # Enable pretty urls
    fastcgi_pass php-handler;
    fastcgi_intercept_errors on;
location ~ ^\/(?:updater|oc[ms]-provider)(?:$|\/) {
    try_files $uri/ =404;
    index index.php;
# Adding the cache control header for js, css and map files
location ~ \.(?:css|js|woff2?|svg|gif|map)$ {
    add_header Cache-Control "public, max-age=15778463";
    # Add headers to serve security related headers (It is intended to
    # have those duplicated to the ones above)
    # this topic first.
    access_log off;
location ^~ /sites/ {
proxy_set_header X-Forwarded-Host $host:$server_port;
proxy_set_header X-Forwarded-Server $host;
proxy_pass https://doc.xxx.com/index.php/apps/cms_pico/pico_proxy/;
proxy_ssl_server_name on;
location ~ .(?:png|html|ttf|ico|jpg|jpeg|bcmap)$ {
# Optional: Don’t log access to other assets
access_log off;
help!!!!!!!
Disable the terms of service app. This will get it to work.
thank you small one ,bu i am need to pico app to work !
If you disable the terms of servcie app pico cms will work. Those two apps uses the same library name but with different versions.
thanks a lot ,when disable terms app ,the pico can run ,
can you tell me ,how to sovles
Why is this marked solved. This is not a solution.
I works for me also, only as workaround. However what I need to do to get working both apps?
This solution doesn’t work for me. When terms_of_service is disabled I get the same error as yia
|Error|index|Exception: Call to undefined method ParsedownExtra::textElements()
  1. /var/www/nextcloud/lib/private/AppFramework/App.php - line 125: OC\AppFramework\Http\Dispatcher->dispatch()|
etc
But when I enable terms of service I get the following error:
Error PHP Trying to access array offset on value of type null at /var/www/nextcloud/apps/terms_of_service/lib/CountryDetector.php#52
I initialized terms_of_service in settings, but that didn’t make a difference. I see that CountryDetector.php is attempting to extract the information from GeoLite2-Country.mmdb but I don’t know why it fails.
So I have not been able to access a test webpage created by cms_pico. This is a new install of nextcloud (first time use for me) and I must say the use of nextcloud has been rocky so far with small issues at every step.
Replying to my previous comment… I found the solution to the cms_pico problem to be found at
where the issues with ParsedownExtra are discussed in detail. As suggested there, my problem was also solved by disabling the Issue Template 0.6.0 app, as well as the Terms of Service app.
Guten Abend,
i can confirme this workaround for this bug ;-).
Thank you,
Urs
Versions:
  • Nextcloud 20.0.4
  • Pico 1.0.12
