true a bit more info would be useful I guess…
Cannot load Zend OPcache - it was already loaded
NextCloudPi version v1.34.7
NextCloudPi image NextCloudPi_07-21-19
distribution Raspbian GNU/Linux 10 \n \l
automount yes
USB devices sda sdb
datadir /media/USBdrive/ncdata
data in SD no
data filesystem btrfs
data disk usage 2.0T/3.7T
rootfs usage 6.9G/29G
swapfile /var/swap
dbdir /var/www/nextcloud2
Nextcloud check ok
Nextcloud version 20.0.4.0
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP ***REMOVED SENSITIVE VALUE***
gateway ***REMOVED SENSITIVE VALUE***
interface eth0
certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
uptime 4days
Nextcloud configuration
"trusted_domains": {
"0": "localhost",
"5": "nextcloudpi.local",
"7": "nextcloudpi",
"8": "nextcloudpi.lan",
"1": "1xxx",
"20": "xxx",
"21": "xxx",
"22": "_",
"4": "fxxx",
"11": "2xxx2"
"dbtype": "mysql",
"version": "20.0.4.0",
"overwrite.cli.url": "https:\/\/xxx\/",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0,
"timeout": 0,
"tempdirectory": "\/media\/USBdrive\/ncdata\/tmp",
"mail_smtpmode": "xxx",
"mail_smtpauthtype": "LOGIN",
"overwriteprotocol": "https",
"logfile": "\/media\/USBdrive\/ncdata\/nextcloud.log",
"loglevel": 1,
"log_type": "file",
"data-fingerprint": "xxxxx",
"theme": "",
"mail_sendmailmode": "smtp",
"jpeg_quality": "60",
"htaccess.RewriteBase": "\/",
"encryption.legacy_format_support": true,
"encryption.key_storage_migrated": false
