Hi, I´ve been changing the PHP memory configuration from automatic to 512M and now I can’t access trough internet explorer or chrome and dns address nighter
Can anyone tell me how can I change or restar the values without formating all please.
I have nextcloud in a Rock64 and I can’t access through ssh
First, main configuration is almost automatic and the you can go to the panel to chenge the nc-limits ( you can see it in teh video) there you put the size of PHP memory and files size
Note that MAXFILESIZE can be at maximum 2G for now, due to limitation of 32bit php.
How to configure
1. Navigate to `nc-limits` in the TUI or the WebUI.
2. Change `MAXFILESIZE` to the desired maximum file size (<=2G).
3. Change `MEMORYLIMIT` to the memory limit you want (default=768M).
4. Click Run or Start.
