PHP memory problem when updating
    • Nextcloud Hub 8 (29.0.4)
    • Debian 12.10
    • httpd 2.4.62-1~deb12u2
    • nginx 1.26.2-v.debian.12+p18.0.67.3+t250217.0844
    • 8.3.19-debian.12.250314.0835
    • yes
    • no
When I launch :
sudo -u laurent /opt/plesk/php/8.3/bin/php --define apc.enable_cli=1 /var/www/vhosts/madonie.org/subdomains/nuage/updater/updater.phar
I get this error message
Verify integrity …PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 250207432 bytes) in phar:///var/www/vhosts/madonie.org/subdomains/nuage/updater/updater.phar/lib/Updater.php on line 674
{"reqId":"IlbEfI84YAlUo8mQpTtC","level":3,"time":"2023-09-26T11:45:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Not installed","userAgent":"--","version":"","exception":{"Exception":"Exception","Message":"Not installed","Code":0,"Trace":[{"file":"/var/www/vhosts/madonie.org/subdomains/nuage/lib/base.php","line":709,"function":"checkInstalled","class":"OC","type":"::"},{"file":"/var/www/vhosts/madonie.org/subdomains/nuage/lib/base.php","line":1196,"function":"init","class":"OC","type":"::"},{"file":"/var/www/vhosts/madonie.org/subdomains/nuage/cron.php","line":43,"args":["/var/www/vhosts/madonie.org/subdomains/nuage/lib/base.php"],"function":"require_once"}],"File":"/var/www/vhosts/madonie.org/subdomains/nuage/lib/base.php","Line":283,"CustomMessage":"--"}}
{"reqId":"7kWlOuEerdghOmb0xSJj","level":3,"time":"2023-09-26T12:00:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Not installed","userAgent":"--","version":"","exception":{"Exception":"Exception","Message":"Not installed","Code":0,"Trace":[{"file":"/var/www/vhosts/madonie.org/subdomains/nuage/lib/base.php","line":709,"function":"checkInstalled","class":"OC","type":"::"},{"file":"/var/www/vhosts/madonie.org/subdomains/nuage/lib/base.php","line":1196,"function":"init","class":"OC","type":"::"},{"file":"/var/www/vhosts/madonie.org/subdomains/nuage/cron.php","line":43,"args":["/var/www/vhosts/madonie.org/subdomains/nuage/lib/base.php"],"function":"require_once"}],"File":"/var/www/vhosts/madonie.org/subdomains/nuage/lib/base.php","Line":283,"CustomMessage":"--"}}
The current PHP memory limit is below the recommended value of 512MB.
            "localhost",
            "nuage.madonie.org"
        "dbtype": "mysql",
        "version": "29.0.4.1",
        "overwrite.cli.url": "http:\/\/localhost",
        "dbport": "",
        "default_phone_region": "FR",
        "theme": "",
        "loglevel": 0,
        "app_install_overwrite": [
            "occweb"
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": 1,
        "mail_smtpport": "993",
        "mail_smtpsecure": "ssl"
PHP :
Version : 8.3.19
Limite de mémoire : 512 MB
Temps d’exécution maximal : 3600
Taille de téléversement maximale : 500 MB
Fréquence de revalidation de l’OPcache : 2
Extensions : Core, date, libxml, openssl, pcre, zlib, bz2, calendar, ctype, hash, filter, ftp, gettext, gmp, json, iconv, SPL, random, Reflection, session, standard, mbstring, SimpleXML, sockets, tokenizer, xml, cgi-fcgi, mysqlnd, bcmath, curl, dba, dom, enchant, fileinfo, gd, imagick, imap, intl, ldap, exif, mysqli, odbc, PDO, pdo_mysql, PDO_ODBC, pdo_pgsql, pdo_sqlite, pgsql, Phar, posix, pspell, redis, soap, sodium, sqlite3, sysvmsg, sysvsem, sysvshm, tidy, xmlreader, xmlwriter, xsl, zip, Zend OPcache
More details here :
https://nuage.madonie.org/info.php
  • activity: 2.21.1
  • circles: 29.0.0-dev
  • cloud_federation_api: 1.12.0
  • comments: 1.19.0
  • contactsinteraction: 1.10.0
  • dashboard: 7.9.0
  • dav: 1.30.1
  • federatedfilesharing: 1.19.0
  • federation: 1.19.0
  • files: 2.1.0
  • files_downloadlimit: 2.0.0
  • files_pdfviewer: 2.10.0
  • files_reminders: 1.2.0
  • files_sharing: 1.21.0
  • files_trashbin: 1.19.0
  • files_versions: 1.22.0
  • firstrunwizard: 2.18.0
  • forms: 4.2.4
  • logreader: 2.14.0
  • lookup_server_connector: 1.17.0
  • nextcloud_announcements: 1.18.0
  • notifications: 2.17.0
  • oauth2: 1.17.0
  • password_policy: 1.19.0
  • photos: 2.5.0
  • privacy: 1.13.0
  • provisioning_api: 1.19.0
  • recommendations: 2.1.0
  • related_resources: 1.4.0
  • serverinfo: 1.19.0
  • settings: 1.12.0
  • sharebymail: 1.19.0
  • support: 1.12.0
  • survey_client: 1.17.0
  • systemtags: 1.19.0
  • tasks: 0.16.0
  • text: 3.10.1
  • theming: 2.4.0
  • twofactor_backupcodes: 1.18.0
  • updatenotification: 1.19.1
  • user_status: 1.9.0
  • viewer: 2.3.0
  • weather_status: 1.9.0
  • workflowengine: 2.11.0
  • admin_audit: 1.19.0
  • bruteforcesettings: 2.9.0
  • deck: 1.13.1 (installed 1.13.1)
  • encryption: 2.17.0
  • files_accesscontrol: 1.19.1 (installed 1.19.1)
  • files_external: 1.21.0
  • files_rightclick: 0.15.1 (installed 1.6.0)
  • groupfolders: 17.0.1 (installed 17.0.1)
  • occweb: 0.2.0 (installed 0.2.0)
  • suspicious_login: 7.0.0
  • twofactor_totp: 11.0.0-dev
  • user_ldap: 1.20.0
For the command line version, you normally have a different php.ini which in your case is set to a much lower value (128 MiB).
sudo -u laurent /opt/plesk/php/8.3/bin/php --ini
I’ve changed the memory_limit in /opt/plesk/php/8.3/etc/php.ini from 128M to 512M, and upgrade has worked. In fact I’ve made a first update of version 29, then an upgrade to version 30, and now I’m told I have version 31 available. Thank you for your help.
