it seems my settings from PHP.ini are not being pulled by my nextcloud installation.
I have placed a PHP.ini with following content in the folder
/www/nextcloud/dev/nextcloud
PHP.INI:
opcache.enable=1
opcache.enable_cli=1
opcache.interned_strings_buffer=8
opcache.max_accelerated_files=10000
opcache.memory_consumption=128
opcache.save_comments=1
opcache.revalidate_freq=1
But anyway my nextcloud admin site reports me:
“PHP Opcache is not correctly enabled"
Add following settings to PHP.INI:
(Actually that’s where I have them from).
I have checked that the right PHP is taken by placing a little script under
www/nextcloud/dev/nextcloud/phpinfo.php
This just calls phpinfo();
When being retrieved, this tells me:
PHP Version: 7.1.2
Configuration File (php.ini) Path : /usr/local/pd-admin2/php-7.1/lib
Loaded Configuration File: /home//www/nextcloud/dev/nextcloud/php.ini
So this looks quite OK for me.
Any ideas how to make some progress? Nothing in the NC logs…
Do I have to place my php.ini into a different folder? Which one…
Regards, Prof
