I’m running NC12 at a server with 6 CPU cores. Currently, between 2 and 4 cores are at 100% usage due to php-fpm process.
Any hints?
Apps:
- activity: 2.5.2
- apporder: 0.4.0
- bruteforcesettings: 1.0.2
- comments: 1.2.0
- dav: 1.3.0
- federatedfilesharing: 1.2.0
- federation: 1.2.0
- files: 1.7.2
- files_external: 1.3.0
- files_sharing: 1.4.0
- files_trashbin: 1.2.0
- files_versions: 1.5.0
- geolocation: 0.0.3
- lookup_server_connector: 1.0.0
- matrixbridge: 0.0.16
- oauth2: 1.0.5
- provisioning_api: 1.2.0
- sharebymail: 1.2.0
- systemtags: 1.2.0
- twofactor_backupcodes: 1.1.1
- updatenotification: 1.2.0
- user_ldap: 1.2.1
- user_ldap_extended: 0.0.6
- workflowengine: 1.2.0
Nextcloud version : 12.0.0
Operating system and version : Debian Strech
Apache or nginx version: Apache 2.4.25
PHP version : 7.0
Is this the first time you’ve seen this error?: yes
Can you reliably replicate it? (If so, please outline steps): yes, the cpu usage is constant
The issue you are facing: Between 2 and 4 cores are at 100% usage due to php-fpm process.
The output of your Nextcloud log in Admin > Logging: nothing related
'instanceid' => '***',
'passwordsalt' => '***',
'secret' => '***',
array ( ***
'datadirectory' => '***',
'overwrite.cli.url' => '***',
'version' => '12.0.0.29',
'dbname' => '***',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => ***,
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'ldapIgnoreNamingRules' => false,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'loglevel' => 3,
'maintenance' => false
