Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can.
30.0.4
Ubuntu 22.04
Apache/2.4.52
HAProxy 2.8.5
- PHP version (e.g, 8.3):
8.3
Yes
End of December
Bare metal in LXC
No
I cannot get any response from the backend. There is connection to Apache, but no response from the application.
I found the following in the log file for PHP-FPM:
server reached pm.max_children setting (8), consider raising it
I have never had the need to tweak anything in here, and this service has been running for years. I raised it to 40 and tweaked the remaining settings to fit the 40 and restarted. It seemed to work. For two days. Then it returned.
server reached pm.max_children setting (40), consider raising it
Now I could just raise it, but I suspects there is a resource leak in Nextcloud. Could be in an app, but I do not know how to troubleshoot that.
N/A
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the Copy raw option from Administration settings->Logging screen or from your nextcloud.log
located in your data directory). Feel free to use a pastebin/gist service if necessary.
I see only timeouts of the applications, as well as timeouts towards the richdocuments proxy endpoint.
Due to the errors in regard to Nextcloud office, I disabled both that and the CODE app. However I still noticed the same thing happening.
PASTE
Nothing other than successfull connections.
The output of occ config:list system
or similar is best, but, if not possible, the contents of your config.php
file from /path/to/nextcloud
is fine (make sure to remove any identifiable information!):
"cloud.domain.tld",
"127.0.0.1",
"xxx.xxx.xxx.xxx",
"localhost",
"www.domain.tld"
"dbtype": "pgsql",
"version": "30.0.4.1",
"overwrite.cli.url": "https:\/\/cloud.domain.tld",
"htaccess.RewriteBase": "\/",
"overwriteprotocol": "https",
"dbport": "5432",
"filelocking.enabled": true,
"redis": {
"port": 0,
"timeout": 0
"data-fingerprint": "d5ecd863f85c5c845d61449e95b9cfcb",
"mail_smtpmode": "sendmail",
"mail_sendmailmode": "pipe",
"default_phone_region": "DK",
"twofactor_enforced": "true",
"MFA"
"twofactor_enforced_excluded_groups": [
"NCNoMFA",
"NoMFA"
"share_folder": "\/Delinger",
"loglevel": 1,
"app_install_overwrite": [
"gestion",
"cas",
"otpmanager",
"secrets",
"cfg_share_links",
"cms_pico",
"files_texteditor",
"side_menu"
"theme": "",
"memories.exiftool": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
"memories.vod.path": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
"log_type": "syslog"
The output of occ app:list
(if possible).
- activity: 3.0.0
- admin_audit: 1.20.0
- announcementcenter: 7.0.1
- app_api: 4.0.3
- approval: 2.0.0
- approve_links: 1.0.2
- assistant: 2.1.1
- bruteforcesettings: 3.0.0
- calendar: 5.0.8
- call_summary_bot: 2.0.0
- cas: 0.2.14
- certificate24: 0.3.5
- cfg_share_links: 6.1.1
- checksum: 1.2.5
- cms_pico: 1.0.21
- comments: 1.20.1
- contacts: 6.1.2
- contactsinteraction: 1.11.0
- dashboard: 7.10.0
- dav: 1.31.1
- dicomviewer: 2.3.0
- end_to_end_encryption: 1.16.1
- event_update_notification: 2.5.0
- external: 5.5.2
- federation: 1.20.0
- files: 2.2.0
- files_accesscontrol: 1.20.1
- files_automatedtagging: 1.20.0
- files_downloadlimit: 3.0.0
- files_notify_redis: 0.3.4
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_sharing: 1.22.0
- files_texteditor: 2.15.1
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- files_zip: 2.1.0
- flow_notifications: 1.10.0
- guests: 4.0.1
- integration_openai: 3.2.0
- larpingapp: 0.1.20
- memegen: 1.1.0
- notifications: 3.0.0
- oauth2: 1.18.1
- oidc: 1.2.0
- otpmanager: 0.5.4
- password_policy: 2.0.0
- photos: 3.0.2
- privacy: 2.0.0
- provisioning_api: 1.20.0
- recommendations: 3.0.0
- related_resources: 1.5.0
- richdocuments: 8.5.3
- richdocumentscode: 24.4.1002
- root_cache_cleaner: 0.1.8
- secrets: 2.1.1
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- side_menu: 4.0.1
- sketch_picker: 2.0.0
- spreed: 20.1.1
- support: 2.0.0
- survey_client: 2.0.0
- suspicious_login: 8.0.0
- systemtags: 1.20.0
- tasks: 0.16.1
- text: 4.1.0
- text_templates: 1.1.0
- theming: 2.5.0
- twofactor_totp: 12.0.0-dev
- twofactor_webauthn: 2.0.0
- updatenotification: 1.20.0
- user_ldap: 1.21.0
- user_status: 1.10.0
- users_picker: 1.0.0
- viewer: 3.0.0
- weather_status: 1.10.0
- workflowengine: 2.12.0
- circles: 30.0.0 (installed 28.0.0-dev)
- collectives: 2.15.2 (installed 2.15.2)
- deck: 1.14.2 (installed 1.14.2)
- encryption: 2.18.0
- externalportal: 1.3.1 (installed 1.3.1)
- files_external: 1.22.0
- files_mindmap: 0.0.30 (installed 0.0.30)
- files_scripts: 4.1.0 (installed 4.1.0)
- firstrunwizard: 3.0.0 (installed 2.16.0)
- forms: 4.3.4 (installed 4.3.4)
- gestion: 2.6.3 (installed 2.6.3)
- gptfreeprompt: 1.0.2 (installed 1.0.2)
- holiday_calendars: 0.3.0 (installed 0.3.0)
- impersonate: 1.17.0 (installed 1.17.0)
- logreader: 3.0.0 (installed 3.0.0)
- mailnotifier: 0.0.3 (installed 0.0.3)
- memories: 7.4.1 (installed 7.4.1)
- notify_push: 0.7.0 (installed 0.7.0)
- passwords: 2024.12.21 (installed 2024.12.21)
- sharerenamer: 3.4.0 (installed 3.4.0)
- stepupauth: 0.2.1 (installed 0.2.1)
- transfer: 0.6.3 (installed 0.6.3)
- uppush: 2.1.2 (installed 2.1.2)
- user_saml: 6.4.1 (installed 6.4.1)
- whiteboard: 1.0.4 (installed 1.0.4)
- Use the
preformatted text
formatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
