Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): 25.0.2
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.41
PHP version (eg, 7.4): 8.0.26
I tried to search this issue in the forum but couldn’t found any, hoping this community can help me. I do not see any error in overview section however Admin longs continuously generating these logs as mentioned in title. I have updated PHP version last week so not sure it this started after upgrade. Please help me to clear these logs:-
Steps to replicate it: I see this continuously not sure how to reproduce.
[PHP] Error: Error: preg_match(): Compilation failed: quantifier does not follow a repeatable item at offset 0 at /var/www/nextcloud/apps/ransomware_protection/lib/Analyzer.php#257 at <<closure>>
0. <<closure>>
OC\Log\ErrorHandler::onError()
1. /var/www/nextcloud/apps/ransomware_protection/lib/Analyzer.php line 257
preg_match()
2. /var/www/nextcloud/apps/ransomware_protection/lib/Analyzer.php line 218
OCA\RansomwareProtection\Analyzer->checkExtension()
3. /var/www/nextcloud/apps/ransomware_protection/lib/CacheWrapper.php line 57
OCA\RansomwareProtection\Analyzer->checkPath()
4. <<closure>>
OCA\RansomwareProtection\CacheWrapper->formatCacheEntry()
5. /var/www/nextcloud/lib/private/Files/Cache/Wrapper/CacheWrapper.php line 104
array_map()
6. /var/www/nextcloud/lib/private/Files/View.php line 1470
OC\Files\Cache\Wrapper\CacheWrapper->getFolderContentsById()
7. /var/www/nextcloud/lib/private/Files/Node/Folder.php line 101
OC\Files\View->getDirectoryContent()
8. /var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php line 260
OC\Files\Node\Folder->getDirectoryListing()
9. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php line 200
OCA\DAV\Connector\Sabre\Directory->getChildren()
10. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 900
Sabre\DAV\Tree->getChildren()
11. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 982
Sabre\DAV\Server->generatePathNodes()
12. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1662
Sabre\DAV\Server->getPropertiesIteratorForPath()
13. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1647
Sabre\DAV\Server->writeMultiStatus()
14. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 346
Sabre\DAV\Server->generateMultiStatus()
15. /var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->httpPropFind()
16. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 472
Sabre\DAV\Server->emit()
17. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 253
Sabre\DAV\Server->invokeMethod()
18. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 321
Sabre\DAV\Server->start()
19. /var/www/nextcloud/apps/dav/lib/Server.php line 360
Sabre\DAV\Server->exec()
20. /var/www/nextcloud/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
21. /var/www/nextcloud/remote.php line 171
require_once("/var/www/nextcl ... p")
PROPFIND /remote.php/dav/files/user/
from x.x.x.x by user at 2023-01-05T14:51:00-05:00
“instanceid”: “REMOVED SENSITIVE VALUE”,
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“10.0.0.112” ],
“datadirectory”: “REMOVED SENSITIVE VALUE”,
“dbtype”: “mysql”,
“version”: “25.0.2.3”,
“overwrite.cli.url”: “http://10.0.0.112”,
“dbname”: “REMOVED SENSITIVE VALUE”,
“dbhost”: “REMOVED SENSITIVE VALUE”,
“dbport”: “”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“installed”: true,
“default_locale”: “en_US”,
“default_phone_region”: “US”,
“logtimezone”: “America/New_York”,
“log_rotate_size”: 52428800,
“htaccess.RewriteBase”: “/”,
“twofactor_enforced”: “true”,
“twofactor_enforced_groups”: ,
“twofactor_enforced_excluded_groups”: ,
“memcache.local”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“filelocking.enabled”: true,
“redis”: {
“host”: “REMOVED SENSITIVE VALUE”,
“port”: 0,
“timeout”: 0
PASTE HERE
PASTE HERE
PASTE HERE
