Sorry to hear youâre facing problems
help.nextcloud.com is for home/non-enterprise users. If youâre running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly.
example
longer
example
here
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can
Nextcloud version (eg, 20.0.5) : 23.0.2
Operating system and version (eg, Ubuntu 20.04) : `Raspbian Bullseye
Apache or nginx version (eg, Apache 2.4.25) : 2.4.52
PHP version (eg, 7.4) : 8.0
troubleshooting this issue:
lead my that ncp does not use the correct php Version of my pi.
Is this the first time youâve seen this error? (Y/N): Y
- move nc-datadir
[ nc-datadir ] (Sat Mar 5 01:36:21 CET 2022)
Maintenance mode enabled
moving data directory from /media/data1/ncdata to /media/data1/ncdata1...
BTRFS filesystem detected
Create subvolume '/media/data1/ncdata1'
Nextcloud is in maintenance mode, hence the database isn't accessible.
Cannot perform any command except 'maintenance:mode --off'
System config value logfile set to string /media/data1/ncdata1/data/nextcloud.log
System config value tempdirectory set to string /media/data1/ncdata1/data/tmp
sed: can't read /etc/php/7.3/cli/php.ini: No such file or directory
Also the ncp.cfg looks wrong
I am on bullseye and use php8.0 as recommended in the documentation.
ânextcloud_versionâ: â23.0.2â,
âphp_versionâ: â7.3â,
âreleaseâ: âbusterâ,
âdatadirâ: â/media/data1/ncdata1/dataâ
