Photo Viewer not working
Nextcloud version : 19.0.3
Operating system and version : Freenas
Apache or nginx version : 2.4.46
PHP version : 7.4
I’m having trouble viewing photos with nextcloud. If I click on an image in file section, it starts downloading the file instead of using the viewer function. And on the photo app, clicking on an image doesn’t do anything.
I’ve tried on occ check-core and check-app for the viewer app and nothing wrong it seems.
Is this the first time you’ve seen this error? : Yes
Error	PHP	Version warning: Imagick was compiled against ImageMagick version 1690 but version 1691 is loaded. Imagick will run but may behave surprisingly at Unknown#0
Error	PHP	imagettftext(): Problem doing text layout at /usr/local/www/nextcloud/lib/private/Preview/TXT.php#92
Have you changed the installation? I do not know “Freenas”. But perhaps there is a conflict between the php-version and the imagemagick-version. On normal linux systems (Debian or Ubuntu) you install “php-imagick” https://packages.debian.org/buster/php-imagick
Read another thread about php-imagick:
Imagick missing - version php 7.3
I didn’t change my installation other than upgrading from 18.X to 19.
Sorry, for the system I meant FreeBsd 11.3. I’ve already installed php-magick for the 7.4 php version. I’ve tried to reinstall it, but it didn’t work.
I’ve got some error on the admin logging (one for each user) also :
{"reqId":"3out8qXe939daziLEb44","level":3,"time":"2020-09-25T06:58:49+00:00","remoteAddr":"","user":"--","app":"files","method":"","url":"--","message":{"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing 'SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = ?) AND (`path_hash` = ?)' with params [5, \"d41d8cd98f00b204e9800998ecf8427e\"]:\n\nSQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php","line":169,"function":"convertException","class":"Doctrine\\DBAL\\Driver\\AbstractMySQLDriver","type":"->","args":["An exception occurred while executing 'SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = ?) AND (`path_hash` = ?)' with params [5, \"d41d8cd98f00b204e9800998ecf8427e\"]:\n\nSQLSTATE[HY000]: General error: 2006 MySQL server has gone away",{"errorInfo":["HY000",2006,"MySQL server has gone away"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"}]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php","line":145,"function":"wrapException","class":"Doctrine\\DBAL\\DBALException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDOMySql\\Driver"},{"errorInfo":["HY000",2006,"MySQL server has gone away"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"},"An exception occurred while executing 'SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = ?) AND (`path_hash` = ?)' with params [5, \"d41d8cd98f00b204e9800998ecf8427e\"]:\n\nSQLSTATE[HY000]: General error: 2006 MySQL server has gone away"]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":911,"function":"driverExceptionDuringQuery","class":"Doctrine\\DBAL\\DBALException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDOMySql\\Driver"},{"errorInfo":["HY000",2006,"MySQL server has gone away"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"},"SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = ?) AND (`path_hash` = ?)",{"1":5,"2":"d41d8cd98f00b204e9800998ecf8427e"}]},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":194,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = ?) AND (`path_hash` = ?)",[5,"d41d8cd98f00b204e9800998ecf8427e"],[1,2],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = :dcValue1) AND (`path_hash` = :dcValue2)",{"dcValue1":5,"dcValue2":"d41d8cd98f00b204e9800998ecf8427e"},{"dcValue1":1,"dcValue2":2}]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":216,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Cache/Cache.php","line":472,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Mount/MountPoint.php","line":272,"function":"getId","class":"OC\\Files\\Cache\\Cache","type":"->","args":[""]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":440,"function":"getStorageRootId","class":"OC\\Files\\Mount\\MountPoint","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":376,"function":"initMountPoints","class":"OC\\Files\\Filesystem","type":"::","args":["adrien"]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Util.php","line":308,"function":"init","class":"OC\\Files\\Filesystem","type":"::","args":["adrien","/adrien/files"]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Utils/Scanner.php","line":116,"function":"setupFS","class":"OC_Util","type":"::","args":["adrien"]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Utils/Scanner.php","line":155,"function":"getMounts","class":"OC\\Files\\Utils\\Scanner","type":"->","args":[""]},{"file":"/usr/local/www/nextcloud/apps-pkg/files/lib/BackgroundJob/ScanFiles.php","line":83,"function":"backgroundScan","class":"OC\\Files\\Utils\\Scanner","type":"->","args":[""]},{"file":"/usr/local/www/nextcloud/apps-pkg/files/lib/BackgroundJob/ScanFiles.php","line":111,"function":"runScanner","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->","args":[{"__class__":"OC\\User\\User"}]},{"file":"/usr/local/www/nextcloud/lib/private/BackgroundJob/Job.php","line":62,"function":"run","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/lib/private/BackgroundJob/TimedJob.php","line":57,"function":"execute","class":"OC\\BackgroundJob\\Job","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]},{"file":"/usr/local/www/nextcloud/cron.php","line":126,"function":"execute","class":"OC\\BackgroundJob\\TimedJob","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php","Line":106,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDOException","Message":"SQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":"HY000","Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":903,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":194,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = ?) AND (`path_hash` = ?)",[5,"d41d8cd98f00b204e9800998ecf8427e"],[1,2],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = :dcValue1) AND (`path_hash` = :dcValue2)",{"dcValue1":5,"dcValue2":"d41d8cd98f00b204e9800998ecf8427e"},{"dcValue1":1,"dcValue2":2}]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":216,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Cache/Cache.php","line":472,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Mount/MountPoint.php","line":272,"function":"getId","class":"OC\\Files\\Cache\\Cache","type":"->","args":[""]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":440,"function":"getStorageRootId","class":"OC\\Files\\Mount\\MountPoint","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":376,"function":"initMountPoints","class":"OC\\Files\\Filesystem","type":"::","args":["adrien"]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Util.php","line":308,"function":"init","class":"OC\\Files\\Filesystem","type":"::","args":["adrien","/adrien/files"]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Utils/Scanner.php","line":116,"function":"setupFS","class":"OC_Util","type":"::","args":["adrien"]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Utils/Scanner.php","line":155,"function":"getMounts","class":"OC\\Files\\Utils\\Scanner","type":"->","args":[""]},{"file":"/usr/local/www/nextcloud/apps-pkg/files/lib/BackgroundJob/ScanFiles.php","line":83,"function":"backgroundScan","class":"OC\\Files\\Utils\\Scanner","type":"->","args":[""]},{"file":"/usr/local/www/nextcloud/apps-pkg/files/lib/BackgroundJob/ScanFiles.php","line":111,"function":"runScanner","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->","args":[{"__class__":"OC\\User\\User"}]},{"file":"/usr/local/www/nextcloud/lib/private/BackgroundJob/Job.php","line":62,"function":"run","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/lib/private/BackgroundJob/TimedJob.php","line":57,"function":"execute","class":"OC\\BackgroundJob\\Job","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]},{"file":"/usr/local/www/nextcloud/cron.php","line":126,"function":"execute","class":"OC\\BackgroundJob\\TimedJob","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","Line":119,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":"HY000","Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","line":117,"function":"execute","class":"PDOStatement","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":903,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":194,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = ?) AND (`path_hash` = ?)",[5,"d41d8cd98f00b204e9800998ecf8427e"],[1,2],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `fileid` FROM `oc_filecache` WHERE (`storage` = :dcValue1) AND (`path_hash` = :dcValue2)",{"dcValue1":5,"dcValue2":"d41d8cd98f00b204e9800998ecf8427e"},{"dcValue1":1,"dcValue2":2}]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":216,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Cache/Cache.php","line":472,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Mount/MountPoint.php","line":272,"function":"getId","class":"OC\\Files\\Cache\\Cache","type":"->","args":[""]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":440,"function":"getStorageRootId","class":"OC\\Files\\Mount\\MountPoint","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":376,"function":"initMountPoints","class":"OC\\Files\\Filesystem","type":"::","args":["adrien"]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Util.php","line":308,"function":"init","class":"OC\\Files\\Filesystem","type":"::","args":["adrien","/adrien/files"]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Utils/Scanner.php","line":116,"function":"setupFS","class":"OC_Util","type":"::","args":["adrien"]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Utils/Scanner.php","line":155,"function":"getMounts","class":"OC\\Files\\Utils\\Scanner","type":"->","args":[""]},{"file":"/usr/local/www/nextcloud/apps-pkg/files/lib/BackgroundJob/ScanFiles.php","line":83,"function":"backgroundScan","class":"OC\\Files\\Utils\\Scanner","type":"->","args":[""]},{"file":"/usr/local/www/nextcloud/apps-pkg/files/lib/BackgroundJob/ScanFiles.php","line":111,"function":"runScanner","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->","args":[{"__class__":"OC\\User\\User"}]},{"file":"/usr/local/www/nextcloud/lib/private/BackgroundJob/Job.php","line":62,"function":"run","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/lib/private/BackgroundJob/TimedJob.php","line":57,"function":"execute","class":"OC\\BackgroundJob\\Job","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]},{"file":"/usr/local/www/nextcloud/cron.php","line":126,"function":"execute","class":"OC\\BackgroundJob\\TimedJob","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","Line":117}},"CustomMessage":"--"},"userAgent":"--","version":"19.0.3.1","id":"5f6d9787d82a8"}
and some 404 error on the httpd-access.log whenever I click on an image from the photo app :
90.127.73.XX - - [25/Sep/2020:09:14:26 +0200] "GET /index.php/apps/logreader/poll?lastReqId=3out8qXe939daziLEb44 HTTP/1.1" 200 2
90.127.73.XX - - [25/Sep/2020:09:14:53 +0200] "PROPFIND /remote.php/dav/files/adrien/ HTTP/1.1" 207 388
90.127.73.XX - - [25/Sep/2020:09:14:53 +0200] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 -
90.127.73.XX - - [25/Sep/2020:09:14:56 +0200] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 -
90.127.73.XX - - [25/Sep/2020:09:15:00 +0200] "GET /index.php/apps/photos/ HTTP/1.1" 200 27252
90.127.73.XX - - [25/Sep/2020:09:15:00 +0200] "GET /index.php/apps/photos/ HTTP/1.1" 200 27262
90.127.73.XX - - [25/Sep/2020:09:15:00 +0200] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 74
90.127.73.XX - - [25/Sep/2020:09:15:01 +0200] "SEARCH /remote.php/dav/ HTTP/1.1" 207 18862
90.127.73.XX - - [25/Sep/2020:09:15:01 +0200] "GET /index.php/core/preview?fileId=108963&x=256&y=256&a=false&v="794471213a8fd4079923f66b17f46625" HTTP/1.1" 404 2
90.127.73.XX - - [25/Sep/2020:09:15:01 +0200] "SEARCH /remote.php/dav/ HTTP/1.1" 207 18792
90.127.73.XX - - [25/Sep/2020:09:15:01 +0200] "GET /index.php/core/preview?fileId=108589&x=256&y=256&a=false&v="cc2f982ff22aadba08e4f47fce6f79c1" HTTP/1.1" 404 2
90.127.73.XX - - [25/Sep/2020:09:15:01 +0200] "GET /index.php/core/preview?fileId=108560&x=256&y=256&a=false&v="8fa4015bf8854a4eafe8aeb3dadab7b0" HTTP/1.1" 404 2
90.127.73.XX - - [25/Sep/2020:09:15:01 +0200] "GET /index.php/core/preview?fileId=108554&x=256&y=256&a=false&v="2c83ca768f2140fe63f19b6f1a150f45" HTTP/1.1" 404 2
You get a 404 error because the preview picture can not be generated. Found in another thread.
Yeah, but even with this error, it doesn’t explain the fact that the viewer doesn’t work, isn’t it ?
Yes
Perhaps you can delete all software from Imagemagick (not only PHP) and reinstall the software.
Ok I found the problem but don’t know how to solve it.
When I’m loading the photo app, my browser console returns that the viewer app is not installed (viewer.js:31 Viewer app is not installed). Weird because, there is the viewer folder in my apps folder AND I did an occ:check-app for the viewer app that didn’t return anything…
I’ve finally solved it by deleting viewer app file from apps/ and apps-pkg/ then reinstalling it manually from a backup.
Hi, I have same problem on version Nextcloud Hub 8 (29.0.5 RC1)
Is there any solution in case that i have no backup and I cannot restore it from backup?
Hey @Karel_H,
I’ve been having the exact same problem as you.
I think the problem lies deeper in Nextcloud…
What’s happening is that the files are present on the server, but it’s sending them over with the wrong MIME type. If you go to the network tab, find the failed modules and open them on a new tab, they download perfectly. They’re also there in both the apps and apps-pkg directories.
This situation is weird and I don’t really know how to approach it since disabling browser MIME type enforcement is not the right way.
I’ll look into what’s happening further and post my findings. :v:
Dummy me. I just had to poke into the MIME types.
You see, behind Nextcloud is a web server. Either Nginx or Apache. And these web servers serve every file required by the front end.
Now, these files include activity-api.mjs, activity-sidebar.mjs and the good old viewer-main.mjs. What I’ve noticed was that every single one of these ends with mjs, an alternative JavaScript file name extension used for modules (hence the m), and that only these files were failing to load.
Long story short, I modified the mime.types file (for me it was located in /usr/local/etc/nginx). There was a line similar to:
application/javascript js;
which I had to rewrite to include mjs files:
application/javascript js mjs;
So yeah, that’s it. This is the solution to anyone having this problem.
I believe it’s the same for people having this problem on Apache.
It’s incredible how such a little change in a config file brings unimaginable amounts of life into Nextcloud’s web interface!
I fixed it in NGINX and added mjs.
Currently there is no error in the browser console, but the photos still don’t show up
EDIT .. It has been solved in version 31.0.4 .. now it works .. no idea what was wrong, but now its ok.
