Using Nextcloud on Truenas. The photo editor colour picker for stroke & shadow for all the tools (text, image, rectangle, pen etc etc) does not work. You can not click on anything.
For the colour picker the cursor changes to a cross when you hover over the colour picker and you can select a colour but on stroke & shadow the cursor does not change to a cross when you hover over the colour picker and you can not select anything.
I have tested with different browsers and on different computers with Windows and/or Linux.
I don’t know why i said that it was fixed because it never was. I must have made a mistake on a long day when i was tired. Or maybe it had been fixed but was then regressed after a further update to not working again.
Anyhow, i have found that you can actually remove the offending html layer that is in the wrong Z position.
I use the stylus browser addon with a script to remove this
.SfxPopper-Overlay {
display: none;
and i widen the colour picker with
.gMTyoX {
max-width: 750px;
You could also use an adblocker like uBlock to remove the blocking layer with the element zapper/picker
add in ublock your-nextcloud-domain.com##.SfxPopper-Overlay
Still like to add, that 31.0.1 has the issue!
But color picking is working partially.
The error now relates to the pen, line, arrow function only.
Here you can open the color picker, but it will close as soon as you try to choose something.
So did it STILL not get fixed yet? I just got a notification from github regarding this bug Here , looks like people are still posting that this bug still exists.
I gave up waiting, if i simple html z-index value cant be fixed after 3 years then god only knows what else is going on behind the back-end that could be a security risk or major problem waiting for some hacker to figure out.
Na, iv dropped NC.
Hope they eventually do fix this for the users but it does not look like it.
I assume that your reply does mean that this bug is still active then?
Pull request! sorry mate , I`m to busy with my own things, i would have no clue where to even start on searching for the right place to even start on NC code, but i would have been sure there are devs that actually do work on this project? maybe not ^^
To be honest, I don’t understand that either, if it really is as easy to fix as you say. But to stop using Nextcloud because of that (I assume that wasn’t the only reason) or to conclude that Nextcloud is a security risk because of that is a bit of a stretch.
But yes, purely based on my gut feeling, I would say it might probably be better for security not to include an image editor at all, because that alone could have security implications. But I’m not a developer, so I can’t really tell.
well yea, it was an “off-the-cuff” post. I was just amazed that i was still getting notifications from this subject. I thought it was all long ago sorted. I prob shouldn’t have posted.
When i say “its a 15 minute job” i mean for the person who built/coded the image editor/annotator, surly for him/her to just change the value of the specific z-index value of a line of html or css would be no more complex than fixing a spelling error.
I would tend to agree with you that it maybe is a bit over-bloated if it takes 3 years to fix a line of code then yea, take the bloat out and just make it as stable and usable as possible.
I don’t actually know (as im not using at any longer) but i might bet that they are busy jamming A.I. into every crevice ATM instead of fixing and stabilising the base app?
Yes, that’s my impression too, and fortunately, also more and more the latter again, for quite some time now.
However, it feels like the Photos app hasn’t received the same attention as other parts of Nextcloud. This is probably because it’s more a home user thing, and not necessarly what business customers would pay for.
