Persistent 'Strict-Transport-Security' warning when running NC locally with Docker, Traefik, self-signed cert
The community help forum (help(dot)nextcloud(dot)com) is for home and non-enterprise users. Support is provided by other community members on a best effort / “as available” basis. All of those responding are volunteering their time to help you.
If you’re using Nextcloud in a business/critical setting, paid and SLA-based support services can be accessed via portal(dot)nextcloud(dot)com where Nextcloud engineers can help ensure your business keeps running smoothly.
Hey folks! I’m working on setting up a new NC instance in Docker, reverse proxied with Traefik - currently using a self-signed cert to simulate as closely as possible a correct HTTPS configuration before I start opening it up to the wider internet. Currently encountering a ‘Strict-Transport-Authority’ message that I’d like to try to clear.
  • Nextcloud version 32.0.5 (from Docker image)
  • OS is Linux Mint 21.3
  • Web server is Apache/2.4.66 (Debian) (from Docker image)
  • Reverse proxy is Traefik 3.6.7
  • PHP version 8.3.30 (from Docker image)
  • Is this the first time you’ve seen this error? Yes
  • When did this problem seem to first start? At install time
  • Installed with Docker Compose (NOT the AIO version - using the apache image)
  • Are you using CloudfIare, mod_security, or similar? No
  • Some additional points potentially worth noting:
    • using Authelia as an auth layer - this is not set up to authenticate NC itself via OAuth yet, currently just gating any access to the page.
    • using a self-signed cert with a self-signed CA
    • testing in Firefox (cert CA correctly added to Firefox’s store - lock icon says Connection Secure)
    • Nextcloud URL added to /etc/hosts file so it targets localhost while I work on it in my dev environment
    • Nothing currently accessible from outside dev environment
Like many others before me, I am unfortunately stuck with this warning on my Overview page:
Some headers are not set correctly on your instance - The `Strict-Transport-Security` HTTP header is not set (should be at least `15552000` seconds). For enhanced security, it is recommended to enable HSTS.
My understanding is that this is almost assuredly a Traefik configuration issue but I’m stumped as to what I’m missing.
  1. From a cold start, stand up Docker containers using docker compose up -d; enable Nextcloud cron job
  2. In Firefox, navigate to nextcloud(dot)mydomain(dot)com, authenticate
  3. From the Nextcloud homepage, navigate to /settings/admin/overview
  4. Observe the warning message present in the “Security & setup warnings” section
None from the day of testing.
Web Browser (Firefox)
Network output upon refresh is 200’s across the board.
Console output upon refresh:
Notifications permissions granted NotificationsApp.vue:449:13
Polling interval updated to 30000 NotificationsApp.vue:412:12
Started background fetcher as session_keepalive is enabled NotificationsApp.vue:279:13
Got notification data, restoring default polling interval. NotificationsApp.vue:368:13
EDIT: adding nextcloud#####headers from Firefox’s local storage for additional info - this seems to indicate that as far as the browser is concerned, HSTS headers are present?
    "cache-control": "no-cache, no-store, must-revalidate",
    "content-encoding": "gzip",
    "content-length": "81",
    "content-security-policy": "default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'",
    "content-type": "application/json; charset=utf-8",
    "date": "(REDACTED)",
    "etag": "(REDACTED)",
    "feature-policy": "autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'",
    "permissions-policy": "camera=(), microphone=(), geolocation=(), payment=(), usb=(), vr=()",
    "referrer-policy": "no-referrer",
    "strict-transport-security": "max-age=15752000; includeSubDomains; preload",
    "x-content-type-options": "nosniff",
    "x-firefox-spdy": "h2",
    "x-frame-options": "SAMEORIGIN",
    "x-nextcloud-user-status": "online",
    "x-permitted-cross-domain-policies": "none",
    "x-powered-by": "PHP/8.3.30",
    "x-request-id": "(REDACTED)",
    "x-robots-tag": "none",
    "x-user-id": "admin",
    "x-xss-protection": "1; mode=block"
Web server / Reverse Proxy (Traefik)
occ config:list system:
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "upgrade.disable-web": true,
            "nextcloud.mydomain.com"
        "dbtype": "mysql",
        "version": "32.0.5.0",
        "overwrite.cli.url": "https:\/\/nextcloud.mydomain.com",
        "mysql.utf8mb4": true,
        "maintenance_window_start": 9
occ app:list output:
  - activity: 5.0.0-dev.0
  - app_api: 32.0.0
  - circles: 32.0.0
  - comments: 1.22.0
  - contactsinteraction: 1.13.1
  - dashboard: 7.12.0
  - dav: 1.34.2
  - federation: 1.22.0
  - files: 2.4.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.1
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - firstrunwizard: 5.0.0-dev.0
  - logreader: 5.0.0-dev.0
  - notifications: 5.0.0-dev.0
  - oauth2: 1.20.0
  - photos: 5.0.0-dev.1
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - support: 4.0.0-dev.0
  - survey_client: 4.0.0-dev.0
  - systemtags: 1.22.0
  - text: 6.0.1
  - theming: 2.7.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - viewer: 5.0.0-dev.0
  - weather_status: 1.12.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - admin_audit: 1.22.0
  - encryption: 2.20.0
  - files_external: 1.24.1
  - twofactor_totp: 14.0.0
  - user_ldap: 1.23.0
Docker configuration
Traefik stack’s docker-compose.yml (composed up first):
services:
  core_proxy:
    container_name: core_proxy
    hostname: core_proxy
    image: traefik:v3.6
    depends_on:
      - core_auth
      - core_ldap
      - core_proxy_socket
    restart: unless-stopped
    security_opt:
      - no-new-privileges:true
    networks:
      - core_proxy
      - core_proxy_socket
    ports:
      - 80:80
      - 443:443
    volumes:
      - $DIR_APPS_CORE_PROXY/rules:/rules:ro
      - $DIR_APPS_CORE_PROXY/traefik.yml:/traefik.yml:ro
      - $DIR_LOGS/core.proxy.log:/logs/traefik.log
      - $DIR_LOGS/core.proxy.access.log:/logs/access.log
      - $DIR_CERTS:/certs
    labels:
      traefik.enable: true
      traefik.http.routers.core_proxy.rule: Host(`traefik.mydomain.com`)
      traefik.http.routers.core_proxy.tls: true
      traefik.http.routers.core_proxy.entryPoints: websecure
      traefik.http.routers.core_proxy.service: api@internal
      traefik.http.routers.core_proxy.middlewares: chain-auth-authelia@file
  core_proxy_socket:
    container_name: core_proxy_socket
    image: lscr.io/linuxserver/socket-proxy:latest
    security_opt:
    networks:
      - core_proxy_socket
    volumes:
    environment:
      LOG_LEVEL: info
      ALLOW_START: 0
      ALLOW_STOP: 0
      ALLOW_RESTARTS: 0
      # allowed by default
      EVENTS: 1
      PING: 1
      VERSION: 1
      # revoked by default
      AUTH: 0
      SECRETS: 0
      POST: 0
      # optional
      BUILD: 0
      COMMIT: 0
      CONFIGS: 0
      CONTAINERS: 1
      DISTRIBUTION: 0
      EXEC: 0
      IMAGES: 0
      INFO: 0
      NETWORKS: 0
      NODES: 0
      PLUGINS: 0
      SERVICES: 0
      SESSION: 0
      SWARM: 0
      SYSTEM: 0
      TASKS: 0
      VOLUMES: 0
      DISABLE_IPV6: 0
  core_auth:
    container_name: core_auth
    hostname: core_auth
    image: authelia/authelia:4.39
    depends_on:
      - core_ldap
    security_opt:
    networks:
      - core_proxy
      - core_ldap
    secrets:
      - ***REMOVED SENSITIVE VALUE(S)***
    volumes:
      - $DIR_APPS_CORE_AUTH/configuration.yml:/config/configuration.yml:ro
      - $DIR_APPS_CORE_AUTH/notification.txt:/config/notification.txt
      - $DIR_DATA_CORE_AUTH:/config/data
      - $DIR_CERTS:/config/certificates
      - $DIR_LOGS/core.auth.log:/config/authelia.log
    environment:
      AUTHELIA_AUTHENTICATION_BACKEND_LDAP_ADDRESS: 'ldap://core_ldap:3890'
      AUTHELIA_AUTHENTICATION_BACKEND_LDAP_BASE_DN: 'dc=mydomain,dc=com'
      AUTHELIA_AUTHENTICATION_BACKEND_LDAP_USER: 'uid=myuid,ou=people,DC=mydomain,DC=com'
      AUTHELIA_IDENTITY_VALIDATION_RESET_PASSWORD_JWT_SECRET_FILE: ***REMOVED SENSITIVE VALUE***
      AUTHELIA_SESSION_SECRET_FILE: ***REMOVED SENSITIVE VALUE***
      AUTHELIA_STORAGE_ENCRYPTION_KEY_FILE: ***REMOVED SENSITIVE VALUE***
      AUTHELIA_AUTHENTICATION_BACKEND_LDAP_PASSWORD_FILE: ***REMOVED SENSITIVE VALUE***
    labels:
      traefik.http.routers.core_auth.rule: Host(`auth.mydomain.com`)
      traefik.http.routers.core_auth.tls: true
      traefik.http.routers.core_auth.entryPoints: websecure
      traefik.http.routers.core_auth.service: core_auth
      traefik.http.routers.core_auth.middlewares: chain-auth-none@file
      traefik.http.services.core_auth.loadBalancer.server.url: http://core_auth:9091
  core_ldap:
    container_name: core_ldap
    hostname: core_ldap
    image: lldap/lldap:stable
    security_opt:
    networks:
      - core_ldap
      - core_proxy
    secrets:
    volumes:
      - $DIR_APPS_CORE_LDAP/lldap_config.toml:/data/lldap_config.toml
      - $DIR_DATA_CORE_LDAP:/data/db
    environment:
      LLDAP_JWT_SECRET_FILE: ***REMOVED SENSITIVE VALUE***
      LLDAP_KEY_SEED_FILE: ***REMOVED SENSITIVE VALUE***
      LLDAP_LDAP_USER_PASS_FILE: ***REMOVED SENSITIVE VALUE***
    labels:
      traefik.http.routers.core_ldap.rule: Host(`sso.mydomain.com`)
      traefik.http.routers.core_ldap.tls: true
      traefik.http.routers.core_ldap.entryPoints: websecure
      traefik.http.routers.core_ldap.service: core_ldap
      traefik.http.routers.core_ldap.middlewares: chain-auth-none@file
      traefik.http.services.core_ldap.loadBalancer.server.url: http://core_ldap:17170
networks:
  core_ldap:
  core_proxy:
    driver: bridge
    ipam:
      config:
        - subnet: 192.168.90.0/24
  core_proxy_socket:
secrets:
Nextcloud stack’s docker-compose.yml (composed up after Traefik - I’ll be using Authelia for single-sign-on in Nextcloud but I haven’t configured that yet):
services:
  cloud:
    container_name: cloud
    hostname: cloud
    image: nextcloud
    depends_on:
      - cloud_db
      - cloud_redis
    security_opt:
    networks:
      - core_proxy
      - cloud_db
      - cloud_harp
      - cloud_redis
    volumes:
      - $DIR_DATA_CLOUD:/var/www/html
    environment:
      NEXTCLOUD_HOSTNAME: nextcloud.mydomain.com
      NEXTCLOUD_TRUSTED_DOMAIN: nextcloud.mydomain.com
      TRUSTED_PROXIES: 192.168.90.0/24
      REDIS_HOST: cloud_redis
    labels:
      traefik.http.routers.cloud.rule: Host(`nextcloud.mydomain.com`)
      traefik.http.routers.cloud.tls: true
      traefik.http.routers.cloud.entryPoints: websecure
      traefik.http.routers.cloud.service: cloud
      traefik.http.routers.cloud.middlewares: chain-auth-authelia-cloud@file
      traefik.http.services.cloud.loadBalancer.server.url: http://cloud:80
  cloud_harp:
    container_name: cloud_harp
    hostname: cloud_harp
    image: ghcr.io/nextcloud/nextcloud-appapi-harp:release
    security_opt:
    networks:
      - cloud_harp
    secrets:
      - cloud_harp_pass
    volumes:
      - $DIR_CERTS:/certs
    environment:
      HP_SHARED_KEY_FILE: ***REMOVED SENSITIVE VALUE***
      NC_INSTANCE_URL: https://nextcloud.mydomain.com
      HP_TRUSTED_PROXY_IPS: 192.168.90.0/24
    labels:
      traefik.http.routers.cloud_harp.rule: Host(`nextcloud.mydomain.com`) && PathPrefix(`/exapps/`)
      traefik.http.routers.cloud_harp.entrypoints: web
      traefik.http.routers.cloud_harp.service: cloud_harp
      traefik.http.services.cloud_harp.loadBalancer.server.url: http://127.0.0.1:8780
  cloud_db:
    container_name: cloud_db
    hostname: cloud_db
    image: mariadb:lts
    security_opt:
    networks:
      - cloud_db
    secrets:
    volumes:
      - $DIR_DATA_CLOUD_DB:/var/lib/mysql
    command:
      --transaction-isolation=READ-COMMITTED
    environment:
      MYSQL_ROOT_PASSWORD_FILE: ***REMOVED SENSITIVE VALUE***
      MYSQL_DATABASE_FILE: ***REMOVED SENSITIVE VALUE***
      MYSQL_USER_FILE: ***REMOVED SENSITIVE VALUE***
      MYSQL_PASSWORD_FILE: ***REMOVED SENSITIVE VALUE***
  cloud_redis:
    container_name: cloud_redis
    hostname: cloud_redis
    image: redis:alpine
    security_opt:
    networks:
      - cloud_redis
networks:
  core_proxy:
    external: true
  cloud_db:
  cloud_harp:
  cloud_redis:
secrets:
traefik.yml:
api:
  dashboard: true
  insecure: true
  debug: false
global:
  checkNewVersion: false
  sendAnonymousUsage: false
providers:
  docker:
    endpoint: tcp://core_proxy_socket:2375
    exposedByDefault: false
    network: core_proxy
  file:
    directory: /rules
    watch: true
# ---HTTP---
entryPoints:
  web:
    address: ":80"
    http:
      redirections:
        entryPoint:
          to: websecure
          scheme: https
          permanent: true
  websecure:
    address: ":443"
# ---LOGGING---
log:
  filePath: /logs/traefik.log
  level: INFO
accessLog:
  filePath: /logs/access.log
  bufferingSize: 100
  filters:
    statusCodes:
      - 204-299
      - 400-499
      - 500-599
dynamic.yml (combined, these are in a handful of files in the rules folder):
tls:
  stores:
    default:
      defaultCertificate:
        certFile: /certs/mydomain.com.crt
        keyFile: /certs/mydomain.com.key
  certificates:
    - certFile: /certs/mydomain.com.crt
      stores:
        - default
http:
  middlewares:
    chain-auth-none:
      chain:
        middlewares:
          - middlewares-rate-limit
          - middlewares-secure-headers
    chain-auth-authelia:
      chain:
        middlewares:
          - middlewares-auth-authelia
    chain-auth-authelia-cloud:
      chain:
        middlewares:
          - middlewares-redirect-cloud
          - middlewares-secure-headers-cloud
    middlewares-auth-authelia:
      forwardAuth:
        address: "http://core_auth:9091/api/verify?rd=https://auth.mydomain.com"
        trustForwardHeader: true
        authResponseHeaders:
          - "Remote-User"
          - "Remote-Groups"
    middlewares-rate-limit:
      rateLimit:
        average: 100
        burst: 50
    middlewares-redirect-cloud:
      redirectRegex:
        permanent: true
        regex: https://(.*)/.well-known/(card|cal)dav
        replacement: https://${1}/remote.php/dav/
    middlewares-secure-headers:
      headers:
        accessControlAllowMethods:
          - GET
          - OPTIONS
          - PUT
        accessControlMaxAge: 100
        hostsProxyHeaders:
          - "X-Forwarded-Host"
        stsSeconds: 63072000
        stsIncludeSubdomains: true
        stsPreload: true
        customFrameOptionsValue: SAMEORIGIN
        contentTypeNosniff: true
        browserXssFilter: true
        referrerPolicy: same-origin
        permissionsPolicy: "camera=(), microphone=(), geolocation=(), payment=(), usb=(), vr=()"
        customResponseHeaders:
          X-Robots-Tag: none,noarchive,nosnippet,notranslate,noimageindex,
          server: ""
    middlewares-secure-headers-cloud:
      headers:
          - GET
          - OPTIONS
          - PUT
        hostsProxyHeaders:
        sslRedirect: true
        stsSeconds: 15752000
        stsPreload: true
        forceSTSHeader: true
        referrerPolicy: no-referrer
        permissionsPolicy: camera=(), microphone=(), geolocation=(), payment=(), usb=(), vr=()
          X-Robots-Tag: none
          server: ""
Happy to provide additional context if it would be useful o7 thanks in advance!
