Pcntl_signal' and 'pcntl_signal_dispatch
    • 31.0.9
    • opensuse Tumbleweed
    • apache2 2.4.64-2.1
    • kein
    • php8 8.4.13-1
    • replace me
    • replace me
    • tar - file
    • yes,
[…der Start des Programms occ führt immer nur zu einer Fehlermeldung
  1. sudo -u wwwrun php occ db:add-missing-columns
  2. The process control (PCNTL) extensions are required in case you want to interrupt long running commands - see PHP: PCNTL - Manual
    Additionally the function ‘pcntl_signal’ and ‘pcntl_signal_dispatch’ need to be enabled in your php.ini.
    Done.
  3. In den beiden php.ini für cli und apache2 gibt es keinen Abschnitt oder Hinweise was man für pcntl_signal eintragen soll.
{"reqId":"l10jYPUH1MpOVKqxyOjs","level":3,"time":"2025-10-10T12:43:02+00:00","remoteAddr":"170.64.197.230","user":"--","app":"index","method":"GET","url":"/alive.php","message":"The requested uri(/alive.php) cannot be processed by the script '/nextcloud/index.php')","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36","version":"31.0.9.1","exception":{"Exception":"Exception","Message":"The requested uri(/alive.php) cannot be processed by the script '/nextcloud/index.php')","Code":0,"Trace":[{"file":"/srv/www/htdocs/nextcloud/lib/private/AppFramework/Http/Request.php","line":737,"function":"getRawPathInfo","class":"OC\\AppFramework\\Http\\Request","type":"->"},{"file":"/srv/www/htdocs/nextcloud/lib/base.php","line":806,"function":"getPathInfo","class":"OC\\AppFramework\\Http\\Request","type":"->"},{"file":"/srv/www/htdocs/nextcloud/lib/base.php","line":1194,"function":"init","class":"OC","type":"::"},{"file":"/srv/www/htdocs/nextcloud/index.php","line":22,"args":["/srv/www/htdocs/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/srv/www/htdocs/nextcloud/lib/private/AppFramework/Http/Request.php","Line":711,"message":"The requested uri(/alive.php) cannot be processed by the script '/nextcloud/index.php')","exception":{},"CustomMessage":"The requested uri(/alive.php) cannot be processed by the script '/nextcloud/index.php')"}}
{"reqId":"oSf8Qj8wsxZF2vd11nFQ","level":3,"time":"2025-10-10T12:43:18+00:00","remoteAddr":"170.64.197.230","user":"--","app":"index","method":"GET","url":"/teorema505?t=1","message":"The requested uri(/teorema505) cannot be processed by the script '/nextcloud/index.php')","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36","version":"31.0.9.1","exception":{"Exception":"Exception","Message":"The requested uri(/teorema505) cannot be processed by the script '/nextcloud/index.php')","Code":0,"Trace":[{"file":"/srv/www/htdocs/nextcloud/lib/private/AppFramework/Http/Request.php","line":737,"function":"getRawPathInfo","class":"OC\\AppFramework\\Http\\Request","type":"->"},{"file":"/srv/www/htdocs/nextcloud/lib/base.php","line":806,"function":"getPathInfo","class":"OC\\AppFramework\\Http\\Request","type":"->"},{"file":"/srv/www/htdocs/nextcloud/lib/base.php","line":1194,"function":"init","class":"OC","type":"::"},{"file":"/srv/www/htdocs/nextcloud/index.php","line":22,"args":["/srv/www/htdocs/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/srv/www/htdocs/nextcloud/lib/private/AppFramework/Http/Request.php","Line":711,"message":"The requested uri(/teorema505) cannot be processed by the script '/nextcloud/index.php')","exception":{},"CustomMessage":"The requested uri(/teorema505) cannot be processed by the script '/nextcloud/index.php')"}}
{"reqId":"6K3rojBXIer9ULINCgN4","level":2,"time":"2025-10-10T13:25:19+00:00","remoteAddr":"192.168.178.20","user":"lothar","app":"PHP","method":"GET","url":"/nextcloud/index.php/apps/mail/api/messages/96748/dkim","message":"Undefined array key 1 at /srv/www/htdocs/nextcloud/apps/mail/vendor/phpmailer/dkimvalidator/src/Validator.php#52","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:143.0) Gecko/20100101 Firefox/143.0","version":"31.0.9.1","data":{"app":"PHP"}}
{"reqId":"3uKd4gdUbJ2vqP9PpPdd","level":2,"time":"2025-10-10T13:27:28+00:00","remoteAddr":"192.168.178.20","user":"lothar","app":"PHP","method":"GET","url":"/nextcloud/index.php/apps/mail/api/messages/96737/dkim","message":"Undefined array key 1 at /srv/www/htdocs/nextcloud/apps/mail/vendor/phpmailer/dkimvalidator/src/Validator.php#52","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:143.0) Gecko/20100101 Firefox/143.0","version":"31.0.9.1","data":{"app":"PHP"}}
{"reqId":"9jFc5hiiLL2vjiOeNQDl","level":2,"time":"2025-10-10T13:51:23+00:00","remoteAddr":"192.168.178.20","user":"lothar","app":"core","method":"GET","url":"/nextcloud/index.php/apps/logreader/api/poll?lastReqId=3uKd4gdUbJ2vqP9PpPdd","message":"Request used more than 300 MB of RAM: 305.1 MB","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:143.0) Gecko/20100101 Firefox/143.0","version":"31.0.9.1","data":{"app":"core"}}
PASTE HERE
PASTE
PASTE HERE
The output of occ config:list system or similar is best, but, if not possible, the contents of your config.php file from /path/to/nextcloud is fine (make sure to remove any identifiable information!)
sudo -u wwwrun php occ config:list system
“system”: {
“instanceid”: “***REMOVED SENSITIVE VALUE***”,
“passwordsalt”: “***REMOVED SENSITIVE VALUE***”,
“secret”: “***REMOVED SENSITIVE VALUE***”,
“trusted_domains”: [
“192.168.178.20”,
xxxxxxxxxxx.de”,
“mainframe”
“default_phone_region”: “DE”,
“default_locale”: “de”,
“force_locale”: “de”,
“datadirectory”: “***REMOVED SENSITIVE VALUE***”,
“dbtype”: “mysql”,
“version”: “31.0.9.1”,
“overwrite.cli.url”: “https:\/\/mainframe\/nextcloud”,
“dbname”: “***REMOVED SENSITIVE VALUE***”,
“dbhost”: “***REMOVED SENSITIVE VALUE***”,
“dbport”: “”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“dbuser”: “***REMOVED SENSITIVE VALUE***”,
“dbpassword”: “***REMOVED SENSITIVE VALUE***”,
“installed”: true,
“allow_local_remote_servers”: true,
“mail_smtpmode”: “smtp”,
“mail_smtpsecure”: “ssl”,
“mail_sendmailmode”: “smtp”,
“mail_from_address”: “***REMOVED SENSITIVE VALUE***”,
“mail_domain”: “***REMOVED SENSITIVE VALUE***”,
“mail_smtphost”: “***REMOVED SENSITIVE VALUE***”,
“mail_smtpport”: “465”,
“mail_smtpauth”: 1,
“mail_smtpname”: “***REMOVED SENSITIVE VALUE***”,
“mail_smtppassword”: “***REMOVED SENSITIVE VALUE***”,
“maintenance”: false,
“debug”: false,
“loglevel”: 2,
“log_type”: “file”,
“log_type_audit”: “file”,
“logfile”: “\/var\/extra\/nextcloud\/data\/nextcloud.log”,
“logfile_audit”: “\/var\/extra\/nextcloud\/data\/audit.log”,
“logfilemode”: 416,
“loglevel_frontend”: 2,
“0”: “logdateformat\” => \“F d, Y H:i:s”,
“maintenance_window_start”: “100”,
“app_install_overwrite”: {
“2”: “maps”,
“3”: “backup”
“theme”: “”,
“allowed_admin_ranges”: [
“127.0.0.1\/8”,
“192.168.0.0\/16”
sudo -u wwwrun php occ app:list
  • activity: 4.0.0
  • admin_audit: 1.21.0
  • app_api: 5.0.2
  • bruteforcesettings: 4.0.0
  • calendar: 5.5.6
  • circles: 31.0.0
  • comments: 1.21.0
  • contacts: 7.3.3
  • contactsinteraction: 1.12.0
  • dashboard: 7.11.0
  • dav: 1.33.0
  • dicomviewer: 2.3.1
  • federation: 1.21.0
  • files: 2.3.1
  • files_downloadlimit: 4.0.0
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • firstrunwizard: 4.0.0
  • fulltextsearch: 31.0.0
  • groupfolders: 19.1.7
  • logreader: 4.0.0
  • mail: 5.5.7
  • maps: 1.6.0
  • metadata: 0.23.0
  • notes: 4.12.3
  • notifications: 4.0.0
  • oauth2: 1.19.1
  • password_policy: 3.0.0
  • photos: 4.0.0
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • spreed: 21.1.5
  • support: 3.0.0
  • survey_client: 3.0.0
  • systemtags: 1.21.1
  • tables: 0.9.5
  • tasks: 0.16.1
  • text: 5.0.0
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_status: 1.11.0
  • viewer: 4.0.0
  • weather_status: 1.11.0
  • webhook_listeners: 1.2.0
  • whiteboard: 1.2.1
  • workflowengine: 2.13.0
  • encryption: 2.19.0
  • files_external: 1.23.0
  • fileslibreofficeedit: 2.0.1 (installed 2.0.1)
  • richdocuments: 8.7.5 (installed 8.7.5)
  • suspicious_login: 9.0.1
  • user_ldap: 1.22.0
You probably just need to install the pcntl PHP module/extension:
The package on Tumbleweed is likely called php8-pcntl or similar.
Super genau das war es.
Vielen vielen Dank
Lothar
