Passman not compatible with NC 14 ?
Hi
Just upgraded to NC 14 and discovered Passman is no more working in it :frowning: Only compatible with NC 13 or lower ! Is it just a simple version test that can be corrected or more serious problem ? I need to extract few datas yet of my Passman in Nextcloud before deleting it so a workaround would be very nice :wink:
Thanks
Vincèn
The compatible version is in the making - just a pull request away.
Refer to https://github.com/nextcloud/passman/tree/fix_layout_for_14
Discussion and install hints here: https://github.com/nextcloud/passman/pull/502
Thanks I subscribed at ticket on github so I’m updated when it’s avalaible for download as regular update (too complicated to do with the explanations on github for code not yet released :slight_smile:
