- Nextcloud 3.15.3 (File sync)
- Fedora 41
- Don’t know
- Don’t know
- PHP version (e.g, 8.3):
- Don’t know
- No
- When using Fedora (I was on MacOS before)
- N/A
- No
I am willing to use the file manager with its contextual menu and overlay icons on files (as described here in the official documentation), but I can’t see any menu nor icon appear.
- Install the Nextcloud Files sync app for Fedora
- Sync folders and files
- See that nothing happens regarding contextual menu/icons (despite a working Tray icon)
N/A
Related posts
I’ve seen a similar issue posted here, but I’m not sure I understand the conclusion correctly: is the contextual menu/icon overlay impossible to install on GNOME?
Thanks ahead for your help! ![]()
