Originally published at: Out-of-band maintenance release for Nextcloud Hub 9 - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 9, we strongly recommend you to update to this version. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the update
This is an out-of-band maintenance release for Nextcloud Hub 9 (version 30.X) that marks its End of Life. We released this additional version to fix the issue with updating.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
- Nextcloud Hub 9 (version 30.0.16, EOL)
Nextcloud Hub 9 (30x) reaches End of Life. What does it mean?
Major versions that have reached their End of Life no longer receive further bug fixes or security updates. Support for major releases may be extended through Nextcloud Enterprise offered by Nextcloud developers via Nextcloud GmbH. For more details to help with planning your updates, check the documentation page.
Join the global launch of Nextcloud Hub 25 Autumn!
Reserve your seat for the online release of Nextcloud Hub 25 Autumn on September 27, 2025, at 10 AM (CEST)
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
