Otf file issue on web administration interface
    • Debian 13 Trixie
    • nginx version: nginx/1.26.3
    • PHP 8.4.11 - Zend Engine v4.4.11 - Zend OPcache v8.4.11
    • since v31 i think
    • Proxmox VM, Debian 11 (install from scratch) upgrade to Debian 12 and Debian 13
I have a problem that appeared in version 31 (if I’m not mistaken). I get an error message in the administration interface saying that the server doesn’t support loading OTF files.
I’ve looked at my server configuration and searched online, but I can’t find a way to remove this error message (although it doesn’t seem to prevent the services I use daily from working).
Have you ever encountered this problem, and more importantly, do you have any suggestions for resolving it?
Thank you very much in advance for your help.
Have a nice evening.
Sincerely.
  1. no idea, just upgrade the server and the issue appear since the version 31
  • Original message in french :
Fichier de police en chargement
Impossible de vérifier la prise en charge du chargement de otf. Veuillez vérifier manuellement si votre serveur Web prend en charge les fichiers `.otf`. Pour autoriser cette vérification, pour devez vous assurer que votre serveur web peut se connecter à lui-même. Il doit donc être capable de résoudre et de se connecter à au moins un de ses `trusted_domains` ou à l'URL `overwrite.cli.url`. Cet échec peut être le résultat d'une erreur de DNS côté serveur ou d'une règle de pare-feu sortante.
  • Google traduction of the message :
Font file loadingUnable to verify support for loading .otf files. Please manually check if your web server supports .otf files. To allow this verification, you must ensure that your web server can connect to itself. Therefore, it must be able to resolve and connect to at least one of its trusted_domains or the URL overwrite.cli.url. This failure may be the result of a server-side DNS error or an outbound firewall rule.
            "benjam.paisiblement.org",
            "nextcloud.chez.wouam",
            "localhost"
        "dbtype": "mysql",
        "version": "32.0.1.2",
        "overwriteprotocol": "https",
        "overwrite.cli.url": "https:\/\/benjam.paisiblement.org\/NextCloud",
        "dbport": "",
        "mysql.utf8mb4": true,
        "mail_smtpmode": "smtp",
        "mail_smtpsecure": "ssl",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "465",
        "mail_smtpauth": 1,
        "redis": {
            "port": 0,
            "dbindex": 0,
            "timeout": 1.5,
        "default_phone_region": "FR",
        "app_install_overwrite": {
            "1": "holiday_calendars",
            "2": "duplicatefinder",
            "3": "libresign",
            "5": "scanner",
            "6": "twainwebscan",
            "7": "talked",
            "8": "camerarawpreviews",
            "9": "folderplayer",
            "10": "news",
            "11": "ransomware_protection"
        "loglevel": 2,
        "memories.exiftool": "\/var\/www\/NextCloud\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/var\/www\/NextCloud\/apps\/memories\/bin-ext\/go-vod-amd64",
        "trashbin_retention_obligation": "30, 35",
        "memories.gis_type": 1,
        "has_rebuilt_cache": true,
        "default_locale": "fr_FR",
        "default_language": "fr",
        "force_language": "fr",
        "default_timezone": "Europe\/Paris"
  - activity: 5.0.0-dev.0
  - calendar: 6.0.4
  - contacts: 8.0.6
  - contactsinteraction: 1.13.1
  - cookbook: 0.11.5
  - dav: 1.34.2
  - files: 2.4.0
  - files_external: 1.24.0
  - files_sharing: 1.24.0
  - files_trashbin: 1.22.0
  - notifications: 5.0.0-dev.0
  - oauth2: 1.20.0
  - photos: 5.0.0-dev.1
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - survey_client: 4.0.0-dev.0
  - theming: 2.7.0
  - updatenotification: 1.22.0
  - viewer: 5.0.0-dev.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - admin_audit: 1.22.0
  - app_api: 32.0.0 (installed 32.0.0)
  - circles: 32.0.0 (installed 27.0.1)
  - comments: 1.22.0 (installed 1.17.0)
  - dashboard: 7.12.0 (installed 7.6.0)
  - encryption: 2.20.0 (installed 2.15.0)
  - federation: 1.22.0 (installed 1.17.0)
  - files_pdfviewer: 5.0.0-dev.0 (installed 2.8.0)
  - files_reminders: 1.5.0 (installed 1.0.0)
  - files_versions: 1.25.0 (installed 1.20.0)
  - firstrunwizard: 5.0.0-dev.0 (installed 2.16.0)
  - logreader: 5.0.0-dev.0 (installed 2.14.0)
  - nextcloud_announcements: 4.0.0-dev.0 (installed 1.16.0)
  - recommendations: 5.0.0-dev.0 (installed 1.5.0)
  - sharebymail: 1.22.0 (installed 1.17.0)
  - support: 4.0.0-dev.0 (installed 1.10.0)
  - systemtags: 1.22.0 (installed 1.17.0)
  - text: 6.0.1 (installed 3.8.0)
  - twofactor_totp: 14.0.0
  - user_ldap: 1.23.0
  - user_status: 1.12.0 (installed 1.6.0)
  - weather_status: 1.12.0 (installed 1.6.0)
Just an up to know if someone could help me or have the same problem?
Thanks in advance
