Since Update NC 25.0.3 to 25.0.4 i get those errors opening the GPX Pod Register with the folder, where my gpx files reside.
[PHP] Fehler: Optional parameter $recursive declared before required parameter $directoryId is implicitly treated as a required parameter at /var/www/nextcloud/apps/gpxpod/lib/Service/ProcessService.php#803
GET /apps/gpxpod/old-ui
from Client-IP by Username at 2023-02-25T08:01:13+01:00
There are no updates for the gpxpod app → using 5.0.4 at the moment
