I’m proposing a feature to allow users to easily disable the power LED on their Nextcloud devices to:
- Reduce minor power consumption
- Minimize visual distraction, especially in dark environments
Current Workaround:
I’ve found a command that successfully turns off the LED:
echo 0 | sudo tee /sys/class/leds/PWR/brightness
To make this persistent across reboots, I’ve added the command to /etc/rc.local:
echo 0 > /sys/class/leds/PWR/brightness
Suggested Implementation:
- Add a toggle switch in the Nextcloud web UI settings
- Potentially integrate this in the upcoming Atom Nextcloud interface
- Allow granular control over system LED behavior
Benefits:
- Energy efficiency (even if minimal)
- Improved user experience
- Customization options for device appearance
Nextcloudpi 1.55.4 on raspberrypi4
