Привет всем, подскажите вчем проблема, куда копать? Nextcloud установлен в Docker? стал выдавать вот такую беду
Сводка
{“reqId”:“rEXVNYaw6Hnm3Dre25Lu”,“level”:0,“time”:“2020-09-13T18:07:10+00:00”,“remoteAddr”:“192.168.1.100”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/apps/files/",“message”:{“Exception”:“OC\AppFramework\Middleware\Security\Exceptions\NotLoggedInException”,“Message”:“Current user is not logged in”,“Code”:401,“Trace”:[{“file”:"/config/www/nextcloud/lib/private/AppFramework/Middleware/MiddlewareDispatcher.php",“line”:98,“function”:“beforeController”,“class”:“OC\AppFramework\Middleware\Security\SecurityMiddleware”,“type”:"->",“args”:[{“class”:“OCA\Files\Controller\ViewController”},“index”]},{“file”:"/config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",“line”:98,“function”:“beforeController”,“class”:“OC\AppFramework\Middleware\MiddlewareDispatcher”,“type”:"->",“args”:[{“class”:“OCA\Files\Controller\ViewController”},“index”]},{“file”:"/config/www/nextcloud/lib/private/AppFramework/App.php",“line”:137,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OCA\Files\Controller\ViewController”},“index”]},{“file”:"/config/www/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php",“line”:47,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:"::",“args”:[“OCA\Files\Controller\ViewController”,“index”,{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{"_route":“files.view.index”}]},{“function”:"__invoke",“class”:“OC\AppFramework\Routing\RouteActionHandler”,“type”:"->",“args”:[{"_route":“files.view.index”}]},{“file”:"/config/www/nextcloud/lib/private/Route/Router.php",“line”:297,“function”:“call_user_func”,“args”:[{“class”:“OC\AppFramework\Routing\RouteActionHandler”},{"_route":“files.view.index”}]},{“file”:"/config/www/nextcloud/lib/base.php",“line”:1012,“function”:“match”,“class”:“OC\Route\Router”,“type”:"->",“args”:["/apps/files/"]},{“file”:"/config/www/nextcloud/index.php",“line”:37,“function”:“handleRequest”,“class”:“OC”,“type”:"::",“args”:[]}],“File”:"/config/www/nextcloud/lib/private/AppFramework/Middleware/Security/SecurityMiddleware.php",“Line”:142,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:80.0) Gecko/20100101 Firefox/80.0”,“version”:“19.0.2.2”}
{“reqId”:“LD82oJ3vIs7EleSWCnja”,“level”:3,“time”:“2020-09-13T18:07:18+00:00”,“remoteAddr”:“192.168.1.100”,“user”:“usernextcloud”,“app”:“no app in context”,“method”:“POST”,“url”:"/login",“message”:“Something is wrong with your openssl setup: error:0200100D:system library:fopen:Permission denied, error:2006D002:BIO routines:BIO_new_file:system lib, error:0E064002:configuration file routines:CONF_load:system lib, error:0200100D:system library:fopen:Permission denied, error:2006D002:BIO routines:BIO_new_file:system lib, error:0E064002:configuration file routines:CONF_load:system lib”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:80.0) Gecko/20100101 Firefox/80.0”,“version”:“19.0.2.2”}
{“reqId”:“LD82oJ3vIs7EleSWCnja”,“level”:3,“time”:“2020-09-13T18:07:18+00:00”,“remoteAddr”:“192.168.1.100”,“user”:“usernextcloud”,“app”:“index”,“method”:“POST”,“url”:"/login",“message”:{“Exception”:“RuntimeException”,“Message”:“OpenSSL reported a problem”,“Code”:0,“Trace”:[{“file”:"/config/www/nextcloud/lib/private/Authentication/Token/PublicKeyTokenProvider.php",“line”:87,“function”:“newToken”,“class”:“OC\Authentication\Token\PublicKeyTokenProvider”,“type”:"->",“args”:["*** sensitive parameter replaced "," sensitive parameter replaced "," sensitive parameter replaced "," sensitive parameter replaced "," sensitive parameter replaced "," sensitive parameter replaced "," sensitive parameter replaced "]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Token/Manager.php",“line”:71,“function”:“generateToken”,“class”:“OC\Authentication\Token\PublicKeyTokenProvider”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/config/www/nextcloud/lib/private/User/Session.php",“line”:682,“function”:“generateToken”,“class”:“OC\Authentication\Token\Manager”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/CreateSessionTokenCommand.php",“line”:68,“function”:“createSessionToken”,“class”:“OC\User\Session”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php",“line”:40,“function”:“process”,“class”:“OC\Authentication\Login\CreateSessionTokenCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/CompleteLoginCommand.php",“line”:48,“function”:“processNextOrFinishSuccessfully”,“class”:“OC\Authentication\Login\ALoginCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php",“line”:40,“function”:“process”,“class”:“OC\Authentication\Login\CompleteLoginCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/LoggedInCheckCommand.php",“line”:61,“function”:“processNextOrFinishSuccessfully”,“class”:“OC\Authentication\Login\ALoginCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php",“line”:40,“function”:“process”,“class”:“OC\Authentication\Login\LoggedInCheckCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/EmailLoginCommand.php",“line”:58,“function”:“processNextOrFinishSuccessfully”,“class”:“OC\Authentication\Login\ALoginCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php",“line”:40,“function”:“process”,“class”:“OC\Authentication\Login\EmailLoginCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/UidLoginCommand.php",“line”:54,“function”:“processNextOrFinishSuccessfully”,“class”:“OC\Authentication\Login\ALoginCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php",“line”:40,“function”:“process”,“class”:“OC\Authentication\Login\UidLoginCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/UserDisabledCheckCommand.php",“line”:57,“function”:“processNextOrFinishSuccessfully”,“class”:“OC\Authentication\Login\ALoginCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php",“line”:40,“function”:“process”,“class”:“OC\Authentication\Login\UserDisabledCheckCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/PreLoginHookCommand.php",“line”:53,“function”:“processNextOrFinishSuccessfully”,“class”:“OC\Authentication\Login\ALoginCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/Authentication/Login/Chain.php",“line”:108,“function”:“process”,“class”:“OC\Authentication\Login\PreLoginHookCommand”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/core/Controller/LoginController.php",“line”:307,“function”:“process”,“class”:“OC\Authentication\Login\Chain”,“type”:"->",“args”:[{“class”:“OC\Authentication\Login\LoginData”}]},{“file”:"/config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",“line”:170,“function”:“tryLogin”,“class”:“OC\Core\Controller\LoginController”,“type”:"->",“args”:[" sensitive parameters replaced ***"]},{“file”:"/config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",“line”:100,“function”:“executeController”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OC\Core\Controller\LoginController”},“tryLogin”]},{“file”:"/config/www/nextcloud/lib/private/AppFramework/App.php",“line”:137,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OC\Core\Controller\LoginController”},“tryLogin”]},{“file”:"/config/www/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php",“line”:47,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:"::",“args”:[“OC\Core\Controller\LoginController”,“tryLogin”,{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{"_route":“core.login.tryLogin”}]},{“function”:"__invoke",“class”:“OC\AppFramework\Routing\RouteActionHandler”,“type”:"->",“args”:[{"_route":“core.login.tryLogin”}]},{“file”:"/config/www/nextcloud/lib/private/Route/Router.php",“line”:297,“function”:“call_user_func”,“args”:[{“class”:“OC\AppFramework\Routing\RouteActionHandler”},{"_route":“core.login.tryLogin”}]},{“file”:"/config/www/nextcloud/lib/base.php",“line”:1012,“function”:“match”,“class”:“OC\Route\Router”,“type”:"->",“args”:["/login"]},{“file”:"/config/www/nextcloud/index.php",“line”:37,“function”:“handleRequest”,“class”:“OC”,“type”:"::",“args”:[]}],“File”:"/config/www/nextcloud/lib/private/Authentication/Token/PublicKeyTokenProvider.php",“Line”:368,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:80.0) Gecko/20100101 Firefox/80.0”,“version”:“19.0.2.2”}
еще есть ньюанс, стоял docker 1.2** после он обновился до версии 2, после чего все накрылось
