- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
30.0.6.2
Debian 6.1.119-1
apache (docker image)
nginx
- PHP version (e.g, 8.3):
docker image version
yes
after logout -> when trying to get a new token from keycloak
Docker Community
no
After I updated my Docker containers to the latest version 30.0.6, it seems the bearer tokens are not passed to nextcloud. I tested with curl, and the tokens appear to be generated correctly (they validate).
I use the OpenID Connect user backend to get user information from a keycloak instance.
The failure only appears once you logged out (it did work for a while because i was already logged in) from nextcloud.
- Install new Nextcloud version 3.0.6.2 via docker
- Logout from any running explorer window
- Try to Login
Debug no app in context RuntimeException: ignorable exception at lib/private/AppConfig.php line 1194 2025-02-14T18:21:19+00:00
0. lib/private/AppConfig.php line 1180
OC\AppConfig->loadConfig(null)
1. lib/private/AppConfig.php line 100
OC\AppConfig->loadConfigAll(
2. lib/private/AllConfig.php line 169
OC\AppConfig->getKeys("bruteForce")
3. lib/private/Security/Bruteforce/Throttler.php line 95
OC\AllConfig->getAppKeys("bruteForce")
4. lib/private/Security/Bruteforce/Throttler.php line 175
OC\Security\Bruteforce\Throttler->isBypassListed("83.219.182.70")
5. lib/private/Security/Bruteforce/Throttler.php line 192
OC\Security\Bruteforce\Throttler->getAttempts("83.219.182.70", "userOidcCode")
6. lib/private/Security/Bruteforce/Throttler.php line 265
OC\Security\Bruteforce\Throttler->getDelay("83.219.182.70", "userOidcCode")
7. .../AppFramework/Middleware/Security/BruteForceMiddleware.php line 52
OC\Security\Bruteforce\Throttler->sleepDelayOrThrowOnMax("83.219.182.70", "userOidcCode")
8. .../Middleware/MiddlewareDispatcher.php line 73
OC\AppFramework\Middleware\Security\BruteForceMiddleware->beforeController(OCA\UserOIDC\Controller\LoginController {}, "code")
9. lib/private/AppFramework/Http/Dispatcher.php line 106
OC\AppFramework\Middleware\MiddlewareDispatcher->beforeController(OCA\UserOIDC\Controller\LoginController {}, "code")
10. lib/private/AppFramework/App.php line 161
OC\AppFramework\Http\Dispatcher->dispatch(OCA\UserOIDC\Controller\LoginController {}, "code")
11. lib/private/Route/Router.php line 302
OC\AppFramework\App::main(
"OCA\\UserOIDC\\Controller\\LoginController",
"code",
OC\AppFramework\DependencyInjection\DIContainer {},
{_route:"user_oidc.login.code"}
12. lib/base.php line 1003
OC\Route\Router->match("\/apps\/user_oidc\/code")
13. index.php line 24
OC::handleRequest(
Debug no app in context OCA\UserOIDC\Controller\LoginController::code uses the @NoCSRFRequired annotation and should use the 2025-02-14T18:21:19+00:00
#[OCP\AppFramework\Http\Attribute\NoCSRFRequired] attribute instead
Debug no app in context OCA\UserOIDC\Controller\LoginController::code uses the @PublicPage annotation and should use the 2025-02-14T18:21:19+00:00
#[OCP\AppFramework\Http\Attribute\PublicPage] attribute instead
**Debug user_oidc No Bearer token** 2025-02-14T18:21:19+00:00
Debug no app in context OC_App::registerLogIn() is deprecated, please register your alternative login option using the registerAlternativeLogin() on the 2025-02-14T18:21:19+00:00
RegistrationContext in your Application class implementing the OCP\Authentication\IAlternativeLogin interface
Interner Serverfehler
Der Server konnte die Anfrage nicht fertig stellen.
Sollte dies erneut auftreten, sende bitte die nachfolgenden technischen Einzelheiten an deinen Server-Administrator.
Weitere Details können im Server-Protokoll gefunden werden.
Weitere Informationen finden Sie in der Dokumentation ↗.
Technische Details
Entfernte Adresse: 83.....
Anfragekennung: UDBs....
PASTE HERE
"htaccess.RewriteBase": "\/",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"upgrade.disable-web": true,
"localhost",
"cloud.flugsportzentrum.at"
"dbtype": "pgsql",
"version": "30.0.6.2",
"overwrite.cli.url": "https:\/\/cloud.flugsportzentrum.at\/",
"dbport": "",
"loglevel": 0,
"log_type": "file",
"log_rotate_size": 10485760,
"log.condition": {
"apps": [
"admin_audit"
"skeletondirectory": "",
"preview_max_x": 2048,
"preview_max_y": 2048,
"jpeg_quality": 70,
"enabledPreviewProviders": {
"1": "OC\\Preview\\Image",
"2": "OC\\Preview\\MarkDown",
"3": "OC\\Preview\\MP3",
"4": "OC\\Preview\\TXT",
"5": "OC\\Preview\\Movie",
"6": "OC\\Preview\\Krita",
"7": "OC\\Preview\\OpenDocument",
"8": "OC\\Preview\\MSOffice2003",
"9": "OC\\Preview\\MSOffice2007",
"10": "OC\\Preview\\MSOfficeDoc",
"enable_previews": true,
"mail_smtpmode": "smtp",
"trashbin_retention_obligation": "auto",
"versions_retention_obligation": "auto",
"activity_expire_days": 30,
"share_folder": "\/Shared",
"overwriteprotocol": "https",
"redis": {
"port": 6379,
"memcache.locking": "OC\\Memcache\\Redis",
"memcache.distributed": "OC\\Memcache\\Redis",
"forbidden_filename_characters": [
"forbidden_filename_extensions": [
".filepart",
".part"
"forbidden_filename_basenames": [
"con",
"prn",
"aux",
"nul",
"com0",
"com1",
"com2",
"com3",
"com4",
"com5",
"com6",
"com7",
"com8",
"com9",
"com\u00b9",
"com\u00b2",
"com\u00b3",
"lpt0",
"lpt1",
"lpt2",
"lpt3",
"lpt4",
"lpt5",
"lpt6",
"lpt7",
"lpt8",
"lpt9",
"lpt\u00b9",
"lpt\u00b2",
"lpt\u00b3"
"mail_smtpsecure": "ssl",
"mail_sendmailmode": "smtp",
"mail_smtpport": "465",
"mail_smtpauth": 1,
"mail_smtppassword": "***REMOVED SENSITIVE VALUE***"
- activity: 3.0.0
- admin_audit: 1.20.0
- announcementcenter: 7.1.0
- app_api: 4.0.6
- bruteforcesettings: 3.0.0
- calendar: 5.0.10
- cfg_share_links: 6.1.1
- circles: 30.0.0
- collectives: 2.16.1
- comments: 1.20.1
- contacts: 6.1.3
- contactsinteraction: 1.11.0
- dashboard: 7.10.0
- dav: 1.31.1
- external: 5.5.2
- federation: 1.20.0
- files: 2.2.0
- files_downloadlimit: 3.0.0
- files_external: 1.22.0
- files_fulltextsearch: 30.0.0
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_sharing: 1.22.0
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- firstrunwizard: 3.0.0
- fulltextsearch: 30.0.0
- fulltextsearch_elasticsearch: 30.0.0
- groupfolders: 18.0.10
- logreader: 3.0.0
- mail: 4.1.2
- notifications: 3.0.0
- notify_push: 1.0.0
- oauth2: 1.18.1
- password_policy: 2.0.0
- polls: 7.2.9
- privacy: 2.0.0
- provisioning_api: 1.20.0
- recommendations: 3.0.0
- related_resources: 1.5.0
- richdocuments: 8.5.3
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- spreed: 20.1.4
- support: 2.0.0
- survey_client: 2.0.0
- systemtags: 1.20.0
- text: 4.1.0
- theming: 2.6.0
- updatenotification: 1.20.0
- user_oidc: 6.2.1
- user_status: 1.10.0
- viewer: 3.0.0
- weather_status: 1.10.0
- workflowengine: 2.12.0
- encryption: 2.18.0
- photos: 3.0.2 (installed 3.0.2)
- side_menu: 4.0.1 (installed 4.0.1)
- suspicious_login: 8.0.0
- twofactor_totp: 12.0.0-dev
- user_ldap: 1.21.0
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
