OPcache issue overflow
    • Nextcloud Hub 10 (31.0.9)
    • Ubuntu Linux 24.04.3
    • Apache 2.4
    • NO
    • 8.3
    • Yes
    • Migration from Plesk to Virtualmin
    • script, now imported with the backup
    • no
After migrating from the Plesk Panel to a Virtualmin panel Nextcloud show the following issue:
The PHP OPcache module is not configured correctly. The OPcache buffer is almost full. To ensure that all scripts can be cached, it is recommended to apply “opcache.memory_consumption” to your PHP configuration with a value greater than “4096.” The OPcache interned strings buffer is nearly full. To ensure that repeating strings can be cached effectively, it is recommended to apply “opcache.interned_strings_buffer” to your PHP configuration with a value greater than “512.”
Link
The output of occ app:list (if possible):
Link
Any idea on how to fix?
I created a small php file to look into Opcache and discovered the cache is not used only by Nextcloud but also from other Wordpress install on other domain (virtual server) on Virtualmin.
My VPS
8 vCore
CPU
16 GB
RAM
480 GB
NVMe
such a setup_warning always comes with a link to docs.. forum search and checking relevant tags like opcache helps as well
I did already before post here.
I tried to change the configuration increasing parameters but this did not help.
OPcache is active.
I don’t remember having this problem with the Plesk panel. The problem is probably how Virtualin handles OPcache. I really don’t know how to fix it.
The issue was on configure OPcache on Virtualmin.
I was using Plesk and migrated just recently to the Virtualmin panel so I’m learning how to manage it.
Opcache experiences saturation issues when using Nextcloud and Virtualmin.
If not configured correctly, it can generate random 500 errors in the browser.
Complete Guide: Configuring OPcache for Virtualmin and Nextcloud
:one: Identifying the correct PHP-FPM
Log in to the server via SSH as root.
Check which PHP FPM is using for the Nextcloud domain:
php -i | grep “Loaded Configuration File”
This will show you the active php.ini, e.g., /etc/php/8.3/fpm/php.ini.
Check for any overrides in the conf.d files:
ls /etc/php/8.3/fpm/conf.d | grep opcache
Usually, there’s 10-opcache.ini.
:two: Edit the OPcache configuration
Open the 10-opcache.ini file:
nano /etc/php/8.3/fpm/conf.d/10-opcache.ini
Add or edit this block (Nextcloud-friendly):
zend_extension=opcache.so
opcache.jit=off
opcache.enable=1
opcache.memory_consumption=512 ; 512 MB for OPcache
opcache.interned_strings_buffer=64 ; buffer stringhe, 64 MB
opcache.max_accelerated_files=60000 ; max number of script memorized
opcache.revalidate_freq=60 ; check timestamp every 60 sec
opcache.validate_timestamps=1
:warning: If there are duplicate parameters in other conf.d .ini files, make sure they don’t overwrite these values.
:three: Restart PHP-FPM and Apache
After saving the file:
systemctl daemon-reload
systemctl restart php8.3-fpm
systemctl restart apache2
Check the status of services:
systemctl status php8.3-fpm
systemctl status apache2
Verify on Nextcloud
