Hello, my freshly installed nextcloud instance from docker using AIO behind a reverse proxy tells me that, the OPcache need to be larger
The PHP OPcache module is not properly configured. See the documentation
for more information.
- The OPcache buffer is nearly full. To assure that all scripts can be hold in cache, it is recommended to apply
opcache.memory_consumption
to your PHP configuration with a value higher than128
How can I adjust this or how do I resolve the issue? I’ve followed exactly the tutorial provided here: How to Install the Nextcloud All-in-One on Linux - Nextcloud and here: all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub
Thanks for any help
Sincerely Groldi
