jakob1
January 25, 2020, 6:56pm
1
after installing the updates from yesterday of
onlyoffice is still working in the browser but don’t load in the Android App:
I deleted an reinstalled the apps, restarted the server, tried different smartphones, nothing helped.
I am very grateful for tips, thanks
I have the same problems - since the update of Onlyoffice and DocumentServer OnlyOffice only works in the browser.
Opening in the app looks similar to trying to open with Collabora
Also reinstalling the two apps did not help
I’m searching for Hints on the Github - but nothing found
I have now manually downgraded OnlyOffice 4.1.2 to 4.1.1.
Now OnlyOffice works again in the Android app.
jakob1
January 25, 2020, 8:44pm
4
Hey, thanks.
It’s working for me, too!
Any ideas where we can report this bug?
# Change Log
## 4.1.2
## Changed
- fix file opening with a sidebar
- fix file opening in Nextcloud Android mobile application
- fix file opening the federated file when watermark is enabled
## 4.1.1
## Changed
- compatible with Nextcloud 16-17
## 4.1.0
## Added
- inline editor if using the same tab, opening the sidebar, sharing from the editor
- creating, editing and co-authoring files in Nextcloud Android mobile application
- setting zoom and autosave
- selection of a file for comparison (DocumentServer 5.5 required)
## Changed
This file has been truncated. show original
odd it mentions it to be a fix… anyways, that repository is the place to report issues.
New Release of OnlyOffice > 4.1.4
Bug was closed:
opened 07:33AM - 26 Jan 20 UTC
closed 10:27AM - 28 Jan 20 UTC
after installing the update to 4.1.2 onlyoffice is still working in the browser but don’t load in the Android App:
If I...
bug
New Release 4.1.4
With this Release Onlyoffice works with Nextcloud Mobile App (Android)
Saulus
September 23, 2021, 11:23am
7
Still not working?
I see this on lastest version but not working on my mobil.
ONLYOFFICE 7.1.2
Changed
fix editing from mobile app
