- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
33.0.3
ubuntu 24.04
NGinx
NGinx
- PHP version (e.g, 8.3):
8.4.21
yes
after pulling documentserver(latest)
docker
no
I have a script that is updating my ONLYOFFICE (docker) with the latest (stable)
two times per month. The latest version i s 9.4.0.1
I can reach my ONLYOFFICE by url OO-FQDN:443 or NC-FQDN:8443 without issues.
The “connector” (ONLYOFFICE App is 10.0.0 from the nextcloud app store) and a self test says connection established (green tag)
When opening documents i get a blank page (word) or a blank table (calc)
With new docs the same.
My ONLYOFFICE docker container resides on the nextcloud server (192.168.55.16)
update docker image for onlyoffice documentserver from 9.3.x to latest(9.4.x)
downgrade to a lower version e.g. with
docker pull onlyoffice/documentserver:9.3.1.2 -
restart docker and container, restart nginx (php), reconnect to nextcloud and see that docs can be edited as expected!
seems that ONLYOFFICE App can no longer make onlyoffice/documentserver docker accessible within nextcloud? Can anyone confirm?
I get the following errors
Error with Feature-Policy header: Some features are specified in both Feature-Policy and Permissions-Policy header: camera, geolocation, microphone, payment. Values defined in Permissions-Policy header will be used.
Error with Permissions-Policy header: Unrecognized feature: 'browsing-topics'.
The FetchEvent for "https://OO-FQDN/9.4.0-ff36968…/web-apps/apps/common/Analytics.js" resulted in a network error response: the promise was rejected.
document_editor_service_worker.js:339
Uncaught (in promise) TypeError: Failed to fetch
at document_editor_service_worker.js:339:21
require.js:1961
GET https://OO-FQDN/9.4.0-ff36968…/web-apps/apps/common/Analytics.js net::ERR_FAILED
and from docker logs -f ONLYOFFICE i get
==> /var/log/onlyoffice/documentserver/nginx.error.log <==
2026/05/20 11:01:09 [error] 11215#11215: *34 open() “/var/www/onlyoffice/documentserver/web-apps/vendor/socketio/socket.io.min.js.map” failed (2: No such file or directory), client: 192.168.55.90, server: , request: “GET /9.4.0-ff369681c3b817a16611f2fa73d6b42a/web-apps/vendor/socketio/socket.io.min.js.map HTTP/1.0”, host: “OO-FQDN”
2026/05/20 11:01:09 [error] 11215#11215: *33 open() “/var/www/onlyoffice/documentserver/web-apps/vendor/underscore/underscore-umd.js.map” failed (2: No such file or directory), client: 192.168.55.90, server: , request: “GET /9.4.0-ff369681c3b817a16611f2fa73d6b42a/web-apps/vendor/underscore/underscore-umd.js.map HTTP/1.0”, host: “OO-FQDN”
192.168.55.90 is my reverse proxy (Nginx)
the nginx conf for ONLYOFFICE is
server {
listen 443 ssl;
# see: https://codefaq.org/server/how-to-address-the-deprecation-of-the-listen-http2-directive-in-nginx/
http2 on;
server_name OO-FQDN;
# SSL Config for all redirected Target URLs
ssl_certificate /etc/letsencrypt/ecc-cert/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/ecc-cert/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/ecc-cert/chain.pem;
ssl_dhparam /etc/nginx/ssl/dhparam.pem;
ssl_session_timeout 1d;
ssl_session_cache shared:SSL:50m;
ssl_session_tickets off;
ssl_protocols TLSv1.2 TLSv1.3;
# Framing-Prevention - do not use this URL for Phishing / Framing
ssl_ciphers 'TLS-CHACHA20-POLY1305-SHA256:TLS-AES-256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA512:DHE-RSA-AES256-GCM-SHA512:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384';
ssl_ecdh_curve X448:secp521r1:secp384r1:prime256v1;
ssl_prefer_server_ciphers on;
set $upstream 192.168.55.16;
# Configuration for OnlyOffice
location / {
proxy_pass https://$upstream:8443;
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $server_name;
The script that is pulling my ONLYOFFICE docker image is
#!/bin/bash
docker stop ONLYOFFICE
docker rm ONLYOFFICE
docker image rm $(docker image ls | grep onlyoffice/documentserver | awk '{ print $3 }')
docker system prune -a -f
cat /etc/letsencrypt/rsa-certs/privkey.pem > /app/onlyoffice/DocumentServer/data/certs/onlyoffice.key
cat /etc/letsencrypt/rsa-certs/fullchain.pem > /app/onlyoffice/DocumentServer/data/certs/onlyoffice.crt
echo "Starte neuen Container ONLYOFFICE; Portmapping 8443:443"
docker run --name=ONLYOFFICE -i -t -d -p 8443:443 --restart=always --add-host=NC_FQDN:192.168.55.16 \
-v /app/onlyoffice/DocumentServer/data:/var/www/onlyoffice/Data \
-v /app/onlyoffice/DocumentServer/logs:/var/log/onlyoffice \
-v /app/onlyoffice/DocumentServer/lib:/var/lib/onlyoffice \
-v /app/onlyoffice/DocumentServer/db:/var/lib/postgresql \
-e JWT_ENABLED='true' -e JWT_SECRET='MY_SECRET' onlyoffice/documentserver:9.3.1.2
# restart services
systemctl restart php8.4-fpm && systemctl restart nginx && systemctl restart postgresql
exit 0
usually i am pulling pull onlyoffice/documentserver (for latest) but for now i switched to a fixed version (9.3.1.2)
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
