Hello guys. Iāve owned a ODROID N2 with Ubuntu 18.04.2 LTS and wanted to install NextCloudPi. The first thing I did was to install docker:
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
Iāve forwarded the ports 80, 443 and 20 in my router (FritzBox).
After that I did what the instructions said:
docker run --restart=always -d -p 4443:4443 -p 443:443 -p 80:80 -v /media/storage/data:/data --name nextcloudpi ownyourbits/nextcloudpi-armhf 192.168.178.47
But after that I could see that it seems to work: System config value trusted_domains => 6 set to string 192.168.178.47
But after that when I go into the docker container and use ncp-config to get into ncp-info:
NextCloudPi version v1.10.0
NextCloudPi image NextCloudPi_docker_03-14-19
distribution Debian GNU/Linux 9 \n \l
automount no
USB devices sda
datadir /data/nextcloud/data
data in SD no
data filesystem ext2/ext3
data disk usage 491M/3.6T
rootfs usage 6.1G/15G
swapfile none
dbdir /data/database
Nextcloud check ok
Nextcloud version 15.0.5.3
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check no
port check 80 closed
port check 443 closed
IP 172.17.0.2
gateway 172.17.0.1
interface eth0
certificates none
NAT loopback no
uptime 22min
I donāt know how the ports canāt be open.
So and when I get on the IP in the browser I just can see:
Initializing NextCloudPi for the first time
Please waitā¦
When I want to use ncp-update I get the error:
fatal: unable to access
āGitHub - nextcloud/nextcloudpi: š¦ Build code for NextcloudPi: Raspberry Pi, Odroid, Rock64, Docker, curl installer...ā:
Could not resolve host: github.com
No internet connectivity
but I can ping GitHub without problemsā¦
I also should mention that I try to install it on a mounted RAID system in a self created folder with
mkdir /media/storage/data
and the filesystem is EXT4.
Forgot to say to most important thing. I know there is already a solution for that but this solution does not work for me. Iāve done this procedure more than 10 times. I deleted the container, the volume and even the image but it does not help.
