this error started appearing in the log: OCSException Reached maximum delay.
There are several hundred records with the same error. I couldnāt find any explanation and reason why it should appear. How do I remove it? Thank you.
If you have that entry, you likely have others like āIP address throttledā, āIP address blockedā, etc. (well, you might need to adjust the log level to see those I guess).
Anyhow, it is Brute Force Protection.
Please check Administration settings->Overview for any warnings or errors, particularly related to your proxy/etc.
Then review the docs here to identify why this might be happening in your environment: Brute force protection ā Nextcloud latest Administration Manual latest documentation
Thank you for your answer, i will look at it. But its strange, Nextcloud is on non-public IP and behind firewall.
Anyway, another errror appearing in the logs
DbalException
An exception occurred while executing a query: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ā15456ā for key āfiles_meta_fileidā issue while saveMetadata
Again, hundreds of records with this error. Entry ID is different every record. It looks like s database error. It can be related?
EDIT: Well i found this record:
IP address blocked because it reached the maximum failed attempts in the last 30 minutes [action: serverinfo, ip: 100.100.102.14]
But that IP is localy on the server. So it blocked itself? ![]()
