OCM-provider problem
    • Debian 12.13
    • Apache 2.4.65
    • no reverse proxy
    • 8.4
    • no
    • se below
    • manual
    • no
In the administration Overview it’s said that there’s an ocm-provider problem.
Here (https://forum.ubuntu-fr.org/viewtopic.php?id=2081998) the solution is to put the “AllowOverride” statement to “All”.
But when I do this my server is not reachable and there are errors message like “ExceptionThe requested uri(/apps/dashboard/) cannot be processed by the script ‘/xxxx/index.php’)
The alternative is : ocm-provider error or server unavailable
  1. Modify the AllowOverride from None to All
Erreur
index
Exception
The requested uri(/apps/dashboard/) cannot be processed by the script '/xxx/index.php')
15 mars 2026, 21:28:14
Erreur
index
Exception
The requested uri(/avatar/unuage/64) cannot be processed by the script '/xxx/index.php')
15 mars 2026, 21:28:13
Erreur
index
Exception
15 mars 2026, 21:28:12
Erreur
index
Exception
The requested uri(/contactsmenu/teams) cannot be processed by the script '/xxx/index.php')
Erreur
index
Exception
The requested uri(/settings/ajax/checksetup) cannot be processed by the script '/xxx/index.php')
Erreur
index
Exception
The requested uri(/apps/theming/theme/dark-highcontrast.css) cannot be processed by the script '/xxx/index.php')
Erreur
index
Exception
The requested uri(/apps/theming/theme/light.css) cannot be processed by the script '/xxx/index.php')
Erreur
index
Exception
The requested uri(/apps/theming/theme/light-highcontrast.css) cannot be processed by the script '/xxx/index.php')
Erreur
index
Exception
The requested uri(/js/core/merged-template-prepend.js) cannot be processed by the script '/xxx/index.php')
Erreur
index
Exception
The requested uri(/apps/theming/theme/opendyslexic.css) cannot be processed by the script '/xxx/index.php')
Erreur
index
Exception
Erreur
index
Exception
The requested uri(/apps/theming/theme/dark.css) cannot be processed by the script '/xxx/index.php')
Erreur
index
Exception
Erreur
index
Exception
Erreur
index
Exception
Erreur
index
Exception
The requested uri(/apps/theming/theme/default.css) cannot be processed by the script '/xxx/index.php')
The working file xxx.conf
<VirtualHost *:80>
    ServerName sss.com
    Redirect permanent / https://sss.com/
    ServerSignature Off
    RewriteEngine On
    RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
</VirtualHost>
<VirtualHost *:443>
    ServerAdmin foo@bar.com
    ServerName sss.com
    DocumentRoot /path/www/xxx/
    <Directory /path/www/xxx/>
       Options -Indexes +FollowSymLinks +MultiViews
       AllowOverride None
       Require all granted
       SetEnv HOME /path/www/xxx
       SetEnv HTTP_HOME /path/www/xxx
    </Directory>
    SSLEngine on
    SSLProtocol All -SSLv2 -TLSv1
    SSLHonorCipherOrder On
    SSLCompression off
    Header set Strict-Transport-Security "max-age=15768000"
    SSLCertificateFile /etc/letsencrypt/live/sss.com/fullchain.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/sss.com/privkey.pem
    <IfModule mod_http2.c>
      Protocols h2 http/1.1
    </IfModule>
    <IfModule mod_headers.c>
       Header always set Strict-Transport-Security "max-age=15768000; includeSubDomains; preload"
    </IfModule>
    <IfModule mod_dav.c>
       Dav off
    </IfModule>
    ErrorLog /var/log/apache2/xxx-error.log
    CustomLog /var/log/apache2/xxx-access.log combined
</VirtualHost>
If someone can help me…
What’s the precise warning message? There are several variations.
But when I do this my server is not reachable and there are errors message like “Exception The requested uri(/apps/dashboard/) cannot be processed by the script ‘/xxxx/index.php’)
Have you see this section of the Installation section of the Admin Manual: Installation on Linux — Nextcloud latest Administration Manual latest documentation
I suspect you’re using a subdirectory installation, but you didn’t post your config so unclear.
The message is
OCS provider resolving
Your web server is not properly set up to resolve “/ocm-provider/”. This is most likely related to a web server configuration that was not updated to deliver this folder directly. Please compare your configuration against the shipped rewrite rules in “.htaccess” for Apache or the provided one in the documentation for Nginx. On Nginx those are typically the lines starting with “location ~” that need an update.
After reading the documentation, I can confirm that I’m using a sub directory, not on NGINX.
But in the .htaccess :
  • there are two sections concerning the mod_rewrite
  • a comment request not to modify one of those sections
After all I try to modify the file, but the error remain.
Should I replace all the lines concerning the mod_rewrite by the commands of the installation guide :
<IfModule mod_rewrite.c>
  RewriteEngine on
  RewriteRule ^\.well-known/carddav /nextcloud/remote.php/dav [R=301,L]
  RewriteRule ^\.well-known/caldav /nextcloud/remote.php/dav [R=301,L]
  RewriteRule ^\.well-known/webfinger /nextcloud/index.php/.well-known/webfinger [R=301,L]
  RewriteRule ^\.well-known/nodeinfo /nextcloud/index.php/.well-known/nodeinfo [R=301,L]
</IfModule>
Hello, I found two .htaccess files :
  • at the root of the web site
  • at the root of the data directory
wich one should I change ?
After installing another instance of Nextcloud from scratch, I finally found the solution.
At the end the .htaccess file stored in the root directory of the site, let’s say /var/www/nextcloud, the lines ErrorDocument and RewriteBase refer to /nextcloud instead of /.
I think it’s because I assigned the value /var/www/nextcloud/ to the DocumentRoot and SetEnv directives in my configuration file.
Whatever the reason, the directive AllowOverride in now assigned to All without problem.
