I know that this problem have been there already several times. I did everything that was to do from the manual. But still I get the error “Returned GID is null ! Is Aria2c running as a daemon”
I use NextCloudPi in a docker container. Does it maybe not work because of this? I don’t know why it does not work. The YouTube Downloader does also not work. It’s installed but i get the error:
“Unable to retrieve true YouTube video URL”
I am on Ubuntu 18.04.2 LTS and NextCloud 16.0.3 but in NextCloudPi !
I have this problem also, since updating to 16.0.4
I have a script to setup ocDownloader after each Nextcloud Docker upgrade, and it worked until then. Now, even if I try to polish the aria2c command line parameters, I still get the “GID null” error.
Is this an issue with Nextcloud 16 ? There’s no complaint I can find about that on the github repo issues page.
Hmm then it’s maybe since 16 because I’ve started my system with 16 and docker and it never worked. But I thought that it’s my fault. The script I tried like 20 times… if the downloader would work, it would be such an amazing feature. I mean the cloud/server is running all the time anyway and you can store the downloads there if you download big files.
@CptDayDreamer The issue seems to come from docker containers themselves. People running nextcloud without Docker do not seem to have this issue. So I’d tend to nail down the issue to some port forwarding issue, or some package missing from the container. Still trying to find a solution but ocdownloader’s maintainer help or a docker specialist’s help would be welcome …
EDIT: Also, Aria seems to be running in background as expected :
@sandy.locke yes that is what I also thought and detected. Aria runs, but it’s like the NextCloud container can’t access aria2c. Maybe Docker-compose im recommended but I hope it’s not because I’m not familiar with this at the moment.
