OCC Web doesn't work in Nextcloud 30.0.0
I have
Nextcloud version 30.0.0
Operating system and version Ubuntu 20.04.6 LTS
Apache or nginx version Apache 2.4.25
PHP version 8.1
Nextcloud 30.0.0 running but OccWeb 0.2.0 gives Internal Error…here the error log:
{"reqId":"xxx","level":3,"time":"2024-10-06T11:08:29+00:00","remoteAddr":"xxx",
"user":"admin","app":"index","method":"GET","url":"/index.php/apps/occweb/","message":"Too few arguments to function OC\\Console\\Application::__construct(), 5 passed in
/var/www/vhosts/mydomaine/nextcloud.mydomaine/apps/occweb/lib/Controller/OccController.php on line 38 and exactly 6 expected",
"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64)
AppleWebKit/537.36 (KHTML, like Gecko) Chrome/109.0.0.0 Safari/537.36","version":"30.0.0.14","exception":
{"Exception":"ArgumentCountError","Message":"Too few arguments to function
 on line 38 and exactly 6 expected","Code":0,"Trace":[{"file":"/var/www/vhosts/mydomaine/nextcloud.mydomaine/apps/occweb/lib/Controller/OccController.php","line":38,"function":"__construct","class":
"OC\\Console\\Application","type":"->"},{"function":"__construct","class":"OCA\\OCCWeb\\Controller\\OccController","type":"->"},
{"file":"/var/www/vhosts/mydomaine/nextcloud.mydomaine/lib/private/AppFramework/Utility/SimpleContainer.php",
"line":98,"function":"newInstanceArgs","class":"ReflectionClass","type":"->"},
"line":106,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},
"line":124,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},
{"file":"/var/www/vhosts/mydomaine/nextcloud.mydomaine/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":448,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/vhosts/mydomaine/nextcloud.mydomaine/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":420,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},
{"file":"/var/www/vhosts/mydomaine/nextcloud.mydomaine/lib/private/AppFramework/App.php","line":140,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},
{"file":"/var/www/vhosts/mydomaine/nextcloud.mydomaine/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},
{"file":"/var/www/vhosts/mydomaine/nextcloud.mydomaine/lib/base.php","line":1001,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/vhosts/mydomaine/nextcloud.mydomaine/index.php","line":24,"function":"handleRequest",
"class":"OC","type":"::"}],"File":"/var/www/vhosts/mydomaine/nextcloud.mydomaine/lib/private/Console/Application.php","Line":29,"message":"Too few arguments to function OC\\Console\\Application::__construct(), 5 passed in /var/www/vhosts/mydomaine/nextcloud.mydomaine/apps/occweb/lib/Controller/OccController.php on line 38 and exactly 6 expected","exception":[],"CustomMessage":"Too few
/var/www/vhosts/mydomaine/nextcloud.mydomaine/apps/occweb/lib/Controller/OccController.php on line 38 and exactly 6 expected"},"id":"67026fb7cdefc"}
has anybody a hint ?
I found this
For version 30 change apps/occweb/lib/ControllerOccController.php with the following code
namespace OCA\OCCWeb\Controller;
use Exception;
use OC;
use OC\Console\Application;
use OC\MemoryInfo;
use OCP\IRequest;
use OCP\AppFramework\Http\TemplateResponse;
use OCP\AppFramework\Http\DataResponse;
use OCP\AppFramework\Controller;
use OCP\ILogger;
use Symfony\Component\Console\Input\StringInput;
use Symfony\Component\Console\Output\OutputInterface;
use Psr\Log\LoggerInterface;
class OccController extends Controller
  private $logger;
  private $userId;
  private $application;
  private $symphonyApplication;
  private $output;
  public function __construct(ILogger $logger, $AppName, IRequest $request, $userId)
    parent::__construct($AppName, $request);
    $this->logger = $logger;
    $this->userId = $userId;
    // Obtendo o IAppManager como sexto argumento
    $this->application = new Application(
      OC::$server->getConfig(),
      OC::$server->get(\OCP\EventDispatcher\IEventDispatcher::class),
      new FakeRequest(),
      OC::$server->get(LoggerInterface::class),
      OC::$server->query(MemoryInfo::class),
      OC::$server->get(\OCP\App\IAppManager::class) // Obtenção do IAppManager
    $this->application->setAutoExit(false);
    $this->output = new OccOutput(OutputInterface::VERBOSITY_NORMAL, true);
    $this->application->loadCommands(new StringInput(""), $this->output);
    $reflectionProperty = new \ReflectionProperty(Application::class, 'application');
    $reflectionProperty->setAccessible(true);
    $this->symphonyApplication = $reflectionProperty->getValue($this->application);
   * @NoCSRFRequired
  public function index()
    return new TemplateResponse('occweb', 'index');
   * @param $input
   * @return string
  private function run($input)
    try {
      $this->application->run($input, $this->output);
      return $this->output->fetch();
    } catch (Exception $ex) {
      $this->logger->logException($ex);
      return "error: " . $ex->getMessage();
   * @param string $command
   * @return DataResponse
  public function cmd($command)
    $this->logger->debug($command);
    $input = new StringInput($command);
    $response = $this->run($input);
    $this->logger->debug($response);
    return new DataResponse($response);
  public function list() {
    $defs = $this->symphonyApplication->all();
    $cmds = array();
    foreach ($defs as $d) {
      array_push($cmds, $d->getName());
    return new DataResponse($cmds);
and its works…
Thanks! That works for me
