Hello guys,
I have some issue with my Nextcloud, it’s working fine before but after some problem on my server, i have restarted and this issue occur.
What happened is i cant really download my files from NC, the files are available in the storage, permission is fine, no config changes afaik.
I have restarted my machine, and re-mount the data disk. But its not fixing the issue.
Anyone facing this issue before, or can help with pointing to the right direction for my troubleshooting?
Thanks
[/details]
Nextcloud version (eg, 20.0.5): 23.0.2
Operating system and version (eg, Ubuntu 20.04): CentOS Linux release 7.9.2009
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.6 (CentOS)
PHP version (eg, 7.4): PHP 7.4.24 (cli)
Y
- sudo -u apache php occ files:scan [user]
In image attachemtn
'redis' =>
'host' => '/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'instanceid' => 'instance',
'loglevel' => 0,
'logtimezone' => 'timzeon',
'passwordsalt' => 'salt',
'secret' => 'secret',
0 => 'domain.com',
1 => 'IP 1',
2 => 'IP 2',
3 => 'IP 3',
'datadirectory' => '/nextcloud_data/nextcloud17/data',
'overwrite.cli.url' => 'https://nextcloud.domain.com',
'overwritecondaddr' => '',
'version' => '23.0.2.1',
'dbname' => 'nextcloud18_db',
'dbhost' => 'dbhost.com:3306',
'dbuser' => 'nextcloud_user',
'dbpassword' => 'password',
'updater.secret' => 'secret',
'twofactor_enforced' => 'true',
0 => 'nextcloud-users',
0 => 'system-user',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'domain.com',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtpdm-ap-southeast-1.aliyun.com',
'mail_smtpport' => '80',
'mail_smtpname' => 'nextcloud@domain.com',
'mail_smtppassword' => 'password',
'data-fingerprint' => 'fingerprint',
> [Sun Jul 17 03:36:01.972893 2022] [lbmethod_heartbeat:notice] [pid 2131] AH02282: No slotmem from mod_heartmonitor
[Sun Jul 17 03:36:02.023268 2022] [mpm_prefork:notice] [pid 2131] AH00163: Apache/2.4.6 (CentOS) PHP/7.4.24 configured -- resuming normal operations
[Sun Jul 17 03:36:02.023286 2022] [core:notice] [pid 2131] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
cat: /sys/class/net/eth0/speed: Invalid argument
cat: /sys/class/net/eth0/duplex: Invalid argument
[Sun Jul 17 16:44:18.314592 2022] [access_compat:error] [pid 12696] [client 100.120.60.115:26584] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[Sun Jul 17 16:45:53.842826 2022] [access_compat:error] [pid 12926] [client 100.120.60.18:10874] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[root@iZ8psf7qfxvt2826z6lim2Z httpd]# tail error_log
PASTE HERE
