- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
32.0.9
Ubuntu server 24.04
- Server version: Apache/2.4.67 (Ubuntu)
replace me
- PHP version (e.g, 8.3):
8.2
yes
after upgrading from 31 to 32
Bare Metal
no
Good morning, I have a question because I’m not entirely sure what to do. Today I updated my Nextcloud to version 32. My admin panel asked me to update the MIME types in my database, and I ran the command: sudo -u www-data php occ maintenance:repair --include-expensive. Everything seemed to be going well until it reached the part about removing activity entries of private events. After two hours, I had to stop and take my Nextcloud installation out of maintenance mode, as I needed it. I decided to check the size of my oc_activity file in the database and found the following:
| Rows | Size (MB) |
| 3754386 | 3159.11 |
The quickest possible solutions I’ve found are to manually edit my database and perform these two actions:
Option A (Recommended): Only delete calendar and event logs to preserve other activity history.
sql
DELETE FROM oc_activity WHERE object_type = 'calendar' OR object_type = 'event';Usa el código con precaución.
Option B (Fastest): Completely wipe the activity history if the table size is massive (hundreds of MBs) and the command above hangs.
sql
TRUNCATE TABLE oc_activity;
My main question is: Would this delete all my users’ calendars? Would all the scheduled appointments be lost? Perhaps I should run the repair command on the weekend and let it run all weekend? (Although in these two hours of work, I haven’t seen the size of the database table decrease.)
Thank you very much for your attention; any advice is welcome.
execute sudo -u www-data occ maintenance:repair --include-expensive
wait for hours stuck at Remove activity entries of private events
It seems nothing changes in oc_activity
I cant find any log of this
not related to web browser
I think we dont need logs
"my.nextcloud.com"
"dbtype": "mysql",
"version": "32.0.9.2",
"overwrite.cli.url": "https:\/\/my.nextcloud.com\/",
"htaccess.RewriteBase": "\/",
"dbport": "",
"mysql.utf8mb4": true,
"mail_smtpauthtype": "PLAIN",
"mail_smtpauth": 1,
"mail_smtpport": "587",
"redis": {
"port": 6379
"has_rebuilt_cache": true,
"app_install_overwrite": [
"circles",
"news",
"twofactor_email"
"mail_smtpmode": "smtp",
"mail_smtpsecure": "tls",
"mail_sendmailmode": "smtp",
"logfile": "\/var\/log\/nextcloud\/nextcloud.log",
"theme": "",
"loglevel": 0,
"default_phone_region": "ES",
"trashbin_retention_obligation": "30",
"default_locale": "eu_ES",
"skeletondirectory": "",
"activity_expire_days": 365
- activity: 5.0.0
- admin_audit: 1.22.0
- app_api: 32.0.0
- bruteforcesettings: 5.0.0
- calendar: 6.4.0
- circles: 32.0.0
- comments: 1.22.0
- contacts: 8.3.10
- contactsinteraction: 1.13.1
- dashboard: 7.12.0
- dav: 1.34.2
- deck: 1.16.4
- files: 2.4.0
- files_downloadlimit: 5.0.0
- files_pdfviewer: 5.0.0
- files_reminders: 1.5.0
- files_sharing: 1.24.1
- files_trashbin: 1.22.0
- files_versions: 1.25.0
- firstrunwizard: 5.0.0
- forms: 5.2.7
- logreader: 5.0.0
- news: 28.3.0
- nextcloud_announcements: 4.0.0
- notes: 5.0.0
- notifications: 5.0.0
- oauth2: 1.20.0
- ownershiptransfer: 1.4.0
- password_policy: 4.0.0
- photos: 5.0.0
- privacy: 4.0.0
- profile: 1.1.0
- provisioning_api: 1.22.0
- quota_warning: 1.23.0
- recommendations: 5.0.0
- related_resources: 3.0.0
- richdocuments: 9.0.6
- richdocumentscode: 25.4.904
- serverinfo: 4.0.0
- settings: 1.15.1
- sharebymail: 1.22.0
- spreed: 22.0.12
- support: 4.0.0
- survey_client: 4.0.0
- suspicious_login: 10.0.0
- systemtags: 1.22.0
- tasks: 0.17.1
- text: 6.0.2
- theming: 2.7.0
- twofactor_totp: 14.0.0
- updatenotification: 1.22.0
- user_status: 1.12.0
- viewer: 5.0.0
- weather_status: 1.12.0
- webhook_listeners: 1.3.0
- workflowengine: 2.14.0
Disabled: - appointments: 2.6.2 (installed 2.6.2)
- bbb: 2.9.1 (installed 2.9.1)
- encryption: 2.20.0
- federation: 1.22.0 (installed 1.6.0)
- files_external: 1.24.1
- polls: 8.6.3 (installed 8.6.3)
- qownnotesapi: 26.2.2 (installed 26.2.2)
- twofactor_email: 2.8.8 (installed 2.8.8)
- twofactor_nextcloud_notification: 6.0.0
- user_ldap: 1.23.0
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
