Nextcloud version (eg, 29.0.5): 29.0.6
Operating system and version (eg, Ubuntu 24.04): Docker version 19.03.11-ol on Oracle Linux Server 7.9
Apache or nginx version (eg, Apache 2.4.25): Built-in Docker Container nextcloud:29.0.6
PHP version (eg, 8.3): Built-in Docker Container nextcloud:29.0.6
Full-text indexing runs successfully for the first approx. 1500 documents, after which a ClientResponseException occurs for each document. The index in Elasticsearch is in state green. The behavior is reproducible.
Is this the first time you’ve seen this error? (Y/N): Yes
- Setup Nextcloud with the following Apps: Full text search, Full text search - Elasticsearch Platform, Full text search - Files
- Setup Elasticsearch single node cluster
- Run
occ fulltextsearch:test. Everythings ok. - Run
occ fulltextsearch:index.
The output of occ fulltextsearch:index:
Options: []
Memory: 232 MB
┌─ Indexing ────
│ Action: fillDocument
│ Provider: Files Account: ***REMOVED SENSITIVE VALUE***
│ Document: 5822920
│ Info: application/vnd.openxmlformats-officedocument.wordprocessingml.document
│ Title: ***REMOVED SENSITIVE VALUE***
│ Content size:
│ Chunk: 444/475
│ Progress: 2/4
┌─ Results ────
│ Result: 13762/13762
│ Index: files:4305714
│ Status: fail
│ Message:
┌─ Errors ────
│ Error: 23972/23972
│ Exception: OCA\FullTextSearch_Elasticsearch\Vendor\Elastic\Elasticsearch\Exception\ClientResponseException
│ Message: unknown error
## x:first result ## c/v:prec/next result ## b:last result
## f:first error ## h/j:prec/next error ## d:delete error ## l:last error
## q:quit ## p:pause
The output of curl "http://elasticsearch:9200/_cat/indices?v":
health status index uuid pri rep docs.count docs.deleted store.size pri.store.size dataset.size
green open my_index o5peityDQa6HsEuKd34Lcw 1 0 1498 0 14.5mb 14.5mb 14.5mb
The output of occ fulltextsearch:check:
Full text search 29.0.1
"search_platform": "OCA\\FullTextSearch_Elasticsearch\\Platform\\ElasticSearchPlatform",
"app_navigation": "1",
"provider_indexed": "",
"cron_err_reset": "1725979246",
"tick_ttl": "1800",
"collection_indexing_list": "50",
"migration_24": "1",
"collection_internal": "local"
- Search Platform:
Elasticsearch 29.0.1 (Selected)
"elastic_host": [
"http://elastic:********@elasticsearch:9200"
"elastic_index": "my_index",
"fields_limit": "10000",
"es_ver_below66": "0",
"elastic_logger_enabled": "true",
"analyzer_tokenizer": "standard",
"allow_self_signed_cert": "false"
- Content Providers:
Deck 1.13.1
Files 29.0.1
"files_local": "1",
"files_external": "0",
"files_group_folders": "1",
"files_encrypted": "0",
"files_federated": "0",
"files_size": "20",
"files_pdf": "1",
"files_office": "1",
"files_image": "0",
"files_audio": "0",
"files_chunk_size": "2"
No errors occoured
"default_phone_region": "DE",
"allow_local_remote_servers": "true",
"overwriteprotocol": "https",
"localhost",
"cloud.bfs.de"
"dbtype": "mysql",
"version": "29.0.6.1",
"overwrite.cli.url": "https:\/\/localhost",
"dbport": "",
"mysql.utf8mb4": true,
"ldapIgnoreNamingRules": false,
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"mail_smtpport": "25",
"loglevel": 0,
"skeletondirectory": "",
"redis": {
"port": "6379",
"maintenance_window_start": "1"
No errors occoured
No errors occoured
Thank you for your support
Felix
