Nextcloud version (eg, 20.0.5): 18.0.12
Operating system and version (eg, Ubuntu 20.04): Ubuntu 18.04.4 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache2 2.4.29
PHP version (eg, 7.4): 7.2.24
The issue you are facing: Some files imported to data folder does not get synced to nextcloud when running sudo -u www-data php occ -vvv files:scan --all
I have circa 7209601 files that weighs about 13Tb in my data dir.
They’re all owned by www-data and have correct rights. About half of the files show up in nextcloud after the occ sync (which takes about 8 hours to run).
Occ finishes with no errors what so ever.
- Import a large amount of files to nextcloud data dir
- Run
My log is filled with these lines:
[webdav] Fatal: OCA\DAV\Connector\Sabre\Exception\Forbidden: No read permissions at <<closure>>
0. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php line 195
OCA\DAV\Connector\Sabre\Directory->getChildren()
1. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 899
Sabre\DAV\Tree->getChildren("files/pom/Inför LR 15.04.2021 NEK")
2. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 978
Sabre\DAV\Server->generatePathNodes(Sabre\DAV\PropFind {}, [Sabre\DAV\PropF ... }])
3. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1666
Sabre\DAV\Server->getPropertiesIteratorForPath("files/pom/Inför LR 15.04.2021 NEK", ["{DAV:}resource ... "], 1)
4. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 355
Sabre\DAV\Server->generateMultiStatus(Generator {}, false)
5. <<closure>>
Sabre\DAV\CorePlugin->httpPropFind(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
6. /var/www/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php line 105
call_user_func_array([Sabre\DAV\CorePlugin {},"httpPropFind"], [Sabre\HTTP\Requ ... }])
7. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 479
Sabre\Event\EventEmitter->emit("method:PROPFIND", [Sabre\HTTP\Requ ... }])
8. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 254
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
9. /var/www/nextcloud/apps/dav/lib/Server.php line 319
Sabre\DAV\Server->exec()
10. /var/www/nextcloud/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
11. /var/www/nextcloud/remote.php line 165
require_once("/var/www/nextcl ... p")
PROPFIND /remote.php/dav/files/pom/Inf%C3%B6r%20LR%2015.04.2021%20NEK
from 10.3.7.227 by pom at 2021-04-14T06:31:44+00:00
'instanceid' => '*',
'passwordsalt' => '*',
'secret' => '*',
0 => '*',
1 => '*',
'datadirectory' => '*',
'overwrite.cli.url' => '*',
'version' => '18.0.12.2',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '*',
'dbpassword' => '*',
'logtimezone' => 'UTC',
'ldapIgnoreNamingRules' => false,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'mail_from_address' => '*',
'mail_smtpmode' => 'smtp',
'mail_domain' => '*',
'mail_smtphost' => '*',
'mail_smtpport' => '*',
'loglevel' => '1',
'ldapUserCleanupInterval' => '5',
'theme' => '',
'remember_login_cookie_lifetime' => 3600,
'session_lifetime' => 3600,
'app_install_overwrite' =>
0 => 'deck',
1 => 'impersonate',
2 => 'files_downloadactivity',
The output of your Apache/nginx/system log in /var/log/apache2/error.log:
[Wed Apr 14 08:27:33.529476 2021] [access_compat:error] [pid 13788] [client 81.226.145.19:61637] AH01797: client denied by server configuration: /var/www/nextcloud/config
[Wed Apr 14 08:31:43.146019 2021] [access_compat:error] [pid 30878] [client 10.3.7.227:55583] AH01797: client denied by server configuration: /var/www/nextcloud/config
[Wed Apr 14 08:36:59.154412 2021] [access_compat:error] [pid 10058] [client 130.243.101.84:62659] AH01797: client denied by server configuration: /var/www/nextcloud/config
[Wed Apr 14 08:42:14.612384 2021] [access_compat:error] [pid 18902] [client 77.218.41.180:49730] AH01797: client denied by server configuration: /var/www/nextcloud/config
