Nextcloud version (eg, 20.0.5): 25.0.2
Operating system and version (eg, Ubuntu 20.04): Yunohost trough Debian
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): 8.0.26
Hello everyone,
I have a problem with nextcloud.
Yesterday, I added a lot of files on my new drive trough command line. But thoses files (pictures, vidéos, pdf…) are not showing into Nextcloud. So I did some research and I found this command to scan all my files.
OCP\HintException: [0]: Memcache \OC\Memcache\APCu not available for local cache (Is the matching PHP module installed and enabled?)
I don’t know what does it mean ? if anyone know something about it
Thank you
Is this the first time you’ve seen this error? (Y/N): YES
Cannot write into "config" directory!
This can usually be fixed by giving the web server write access to the config directory.
But, if you prefer to keep config.php file read only, set the option "config_is_read_only" to true in it.
But I don’t really find info about it in the “search section”
