Nextcloud version (eg, 20.0.5): 27.0.0 in Docker (27.0.0-apache)
Operating system and version (eg, Ubuntu 20.04): Fedora
Apache or nginx version (eg, Apache 2.4.25): Apache in Docker image
PHP version (eg, 7.4): PHP in Docker image
I went through the upgrade from NC 25.0.7 to NC 26 and then NC 27.0.0. Migration process went without any error. The occ status
seems fine:
- installed: true
- version: 27.0.0.8
- versionstring: 27.0.0
- edition:
- maintenance: false
- needsDbUpgrade: false
- productname: Nextcloud
- extendedSupport: false
But when I log in and open Files app, I face an error in the DevTools Console and the area, where file list should show is blank (white). The Photos app loads fine and displays what I expected.
The error:
app.js:54 Uncaught TypeError: OCA.Files.Navigation is not a constructor
at Object.initialize (app.js:54:22)
at app.js:445:17
at regexp-tree.js:406:6
- Upgrade from 25.0.7 to NC 27 (spotted also on NC26)
The output of your Nextcloud log in Admin > Logging: no error, only debug
[logreader] Debug: Could not find resource file "/apps/logreader/css/../js/logreader-main.css"
GET /settings/admin/logging
from 109.230.41.6 by admin at 2023-06-18T19:21:38+00:00
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'redis' =>
'host' => 'redis',
'password' => 'REDACTED',
'port' => 6379,
'trusted_proxies' =>
0 => '172.18.0.0/16',
'passwordsalt' => 'REDACTED',
'secret' => 'REDACTED',
0 => 'localhost',
1 => 'REDACTED',
2 => 'REDACTED',
'dbtype' => 'pgsql',
'version' => '27.0.0.8',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbuser' => 'REDACTED',
'dbpassword' => 'REDACTED',
'instanceid' => 'REDACTED',
'loglevel' => 0,
'theme' => '',
'app_install_overwrite' =>
0 => 'files_mindmap',
1 => 'drawio',
'debug' => true,
'log_type' => 'file',
'logfile' => 'nextcloud_log.log',
'logdateformat' => 'F d, Y H:i:s',
It seems there are other errors. I found another JS one in Dashboard, but unsure if it is related:
bootstrap:15 Uncaught TypeError: Cannot read properties of undefined (reading 'call')
at o (bootstrap:15:13)
at 25714 (chunk loaded:1:5)
at core-unsupported-browser-redirect.js:2:2798
at o.O (chunk loaded:26:14)
at core-unsupported-browser-redirect.js:2:2814
at core-unsupported-browser-redirect.js:2:2819
Proxying an event bus of version 2.1.1 with 1.3.0
e @ index.es.js:627
70903 @ index.es.js:1351
i @ core-unified-search.js:2
71894 @ floating-ui.core.browser.min.mjs:1
22200 @ floating-ui.core.browser.min.mjs:1
55058 @ main.js:18
17499 @ main.js:19
56874 @ chunk loaded:1
(anonymous) @ core-unified-search.js:2
i.O @ core-unified-search.js:2
ocdialog.js:252 jQuery is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own.
Un @ ocdialog.js:252
get @ ocdialog.js:262
(anonymous) @ trusted-types.js:1
(anonymous) @ resource-timing.js:1
19755 @ resource-timing.js:1
r @ .*$:7
2784 @ chunk loaded:1
r @ .*$:7
(anonymous) @ .*$:116
r.O @ .*$:33
(anonymous) @ .*$:117
(anonymous) @ .*$:118
ocdialog.js:252 $ is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own.
r @ .*$:7
r @ .*$:7
r.O @ .*$:33
index.es.js:627 Proxying an event bus of version 2.1.1 with 1.3.0
e @ index.es.js:627
r @ .*$:7
r @ .*$:7
r @ .*$:7
4820 @ index.es.js:1358
r @ .*$:7
r @ .*$:7
r.O @ .*$:33
Sidebar.vue:485 OCA.Files.Sidebar initialized
sidebar.js:36 OCA.Files.Sidebar initialized
bootstrap:19 Uncaught TypeError: Cannot read properties of undefined (reading 'call')
at o (bootstrap:19:32)
at 95754 (chunk loaded:1:5)
at files-reference-files.js:2:10214
at o.O (chunk loaded:25:12)
at files-reference-files.js:2:10229
at files-reference-files.js:2:10235
at a (bootstrap:19:32)
at 24103 (chunk loaded:1:5)
at files_sharing-files_sharing_tab.js:2:85140
at a.O (chunk loaded:25:12)
at files_sharing-files_sharing_tab.js:2:85155
at files_sharing-files_sharing_tab.js:2:85161
a @ bootstrap:19
24103 @ chunk loaded:1
a @ bootstrap:19
(anonymous) @ files_sharing-files_sharing_tab.js:2
a.O @ chunk loaded:25
at 24308 (chunk loaded:1:5)
at dashboard-main.js:2:43837
at dashboard-main.js:2:43852
at dashboard-main.js:2:43858
o @ bootstrap:19
24308 @ chunk loaded:1
o @ bootstrap:19
(anonymous) @ dashboard-main.js:2
o.O @ chunk loaded:25
Sidebar.vue:1 Uncaught Error: The icon argument is not a valid string
at new e (Sidebar.vue:1:1255)
at sidebar.js:38:21
at sidebar.js:66:45
at sidebar.js:66:45
Thank you for your help.
