example
longer
example
here
Nextcloud version: 22.1.0
Operating system and version: Debian 10.10 (buster)
nginx version: 1.14.2
PHP version: 7.4
When i tried to configure memcache.distributed to Redis I get this error:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
Is this the first time you’ve seen this error? : Y
- Add redis distributed configuration to config.php
- Load nextcloud
When the distributed redis is not in the config file the memcache.locking is working, so it seems that communication between nextcloud and redis localy is good.
Nothing in the log
The output of your config.php file in /var/www/nextcloud
'instanceid' => 'XXXXXX',
'passwordsalt' => 'XXXXXXXX',
'secret' => 'XXXXXXX',
0 => 'mydomain.com',
1 => '1.1.1.1',
'datadirectory' => '/var/nc_data',
'version' => '22.1.0.1',
'overwrite.cli.url' => 'https://mydomain.com',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'XXXXXXX',
'logfile' => '/var/nc_data/nextcloud.log',
'loglevel' => 0,
'logtimezone' => 'Europe/Paris',
'log_rotate_size' => 104857600,
'mail_smtpmode' => 'smtp',
'mail_domain' => 'mail.fr',
'mail_smtpauth' => 1,
'mail_smtphost' => 'mail.fr',
'mail_smtpname' => 'test@mail.fr',
'mail_smtppassword' => 'XXXXXX',
'mail_smtpsecure' => 'ssl',
'mail_smtpport' => '465',
'default_phone_region' => 'FR',
'redis' =>
'host' => '/run/redis/redis-server.sock',
'port' => 0,
'dbindex' => 0,
'password' => 'XXXXXXX',
'timeout' => 1.5,
The output of your nginx log in /var/log/nginx/error.log
mydomain.com, request: "GET /.well-known/webfinger HTTP/1.0", host: "mydomain.com"
2021/08/12 14:39:12 [error] 12471#12471: *149 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught OC\HintException: [0]: Memcache \OC\Memcache\Redis not available for distributed cache (Is the matching PHP module installed and enabled?)
thrown in /var/www/nextcloud/lib/private/Memcache/Factory.php on line 94" while reading response header from upstream, client: 192.168.0.2, server: mydomain.com, request: "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock:", host: "mydomain.com"
