Hi guys, my server was running well until I the following error appear:
Nextcloud version: 12.0.4
Operating system and version: Raspbian Stretch 9.3
Apache version: 2.4.25-3
PHP version: 7.0.19-1
Is this the first time you’ve seen this error?: Y
Steps to replicate it: it just appeared
The output of your Nextcloud log in Admin > Logging: Can’t access web interface
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
'instanceid' => 'instanceid123',
'passwordsalt' => 'supersecretpasssalt',
'secret' => 'supersecret',
0 => 'mydomain.com',
'datadirectory' => '/media/nextcloud-data',
'overwrite.cli.url' => 'https://mydomain.com',
'version' => '12.0.4.3',
'dbname' => 'nextcloud516970',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'mysupersecretpassword',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'password' => 'mysupersecretpassword',
'timeout' => 1.5,
'theme' => '',
'loglevel' => 2,
The output of your Apache/nginx/system log in /var/log/____: apache is running good
Apparently the table oc_filecache is corrupted:
Next Doctrine\DBAL\Exception\DriverException: An exception occurred while executing 'SELECT `fileid`, `storage`, `path`, `path_hash`, `parent`, `name`, `mimetype`, `mimepart`, `size`, `mtime`,
`storage_mtime`, `encrypted`, `etag`, `permissions`, `checksum`
FROM `oc_filecache` WHERE `storage` = ? AND `path_hash` = ?' with params [1, "e029105427ddbaca919c2efde8b7ba73"]:
SQLSTATE[42S02]: Base table or view not found: 1932 Table 'nextcloud516970.oc_filecache' doesn't exist in engine in /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php:116
Stack trace:
#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(128): Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\DBAL\Driver\PDOException))
#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(855): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Driver\PDOException), 'SELECT `fileid`...', Array)
#2 /var/www/html/nextcloud/lib/private/DB/Connection.php(192): Doctrine\DBAL\Connection->executeQuery('SELECT `fileid`...', Array, Array, NULL)
#3 /var/www/html/nextcloud/lib/private/Files/Cache/Cache.php(137): OC\DB\Connection->executeQuery('SELECT `fileid`...', Array)
#4 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Encryption.php(929): OC\Files\Cache\Cache->get('files_encryptio...')
#5 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Encryption.php(949): OC\Files\Storage\Wrapper\Encryption->getHeader('files_encryptio...')
#6 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Encryption.php(205): OC\Files\Storage\Wrapper\Encryption->getEncryptionModule('files_encryptio...')
#7 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(240): OC\Files\Storage\Wrapper\Encryption->file_get_contents('files_encryptio...')
#8 /var/www/html/nextcloud/lib/private/Files/View.php(1156): OC\Files\Storage\Wrapper\Wrapper->file_get_contents('files_encryptio...')
#9 /var/www/html/nextcloud/lib/private/Files/View.php(600): OC\Files\View->basicOperation('file_get_conten...', '/files_encrypti...', Array)
#10 /var/www/html/nextcloud/lib/private/Encryption/Keys/Storage.php(213): OC\Files\View->file_get_contents('/files_encrypti...')
#11 /var/www/html/nextcloud/lib/private/Encryption/Keys/Storage.php(107): OC\Encryption\Keys\Storage->getKey('/files_encrypti...')
#12 /var/www/html/nextcloud/apps/encryption/lib/KeyManager.php(569): OC\Encryption\Keys\Storage->getSystemUserKey('pubShare_7adb8a...', 'OC_DEFAULT_MODU...')
#13 /var/www/html/nextcloud/apps/encryption/lib/KeyManager.php(157): OCA\Encryption\KeyManager->getPublicShareKey()
#14 /var/www/html/nextcloud/apps/encryption/lib/Users/Setup.php(86): OCA\Encryption\KeyManager->validateShareKey()
#15 /var/www/html/nextcloud/apps/encryption/lib/AppInfo/Application.php(73): OCA\Encryption\Users\Setup->setupSystem()
#16 /var/www/html/nextcloud/apps/encryption/appinfo/app.php(30): OCA\Encryption\AppInfo\Application->__construct(Array, true)
#17 /var/www/html/nextcloud/lib/private/legacy/app.php(209): require_once('/var/www/html/n...')
#18 /var/www/html/nextcloud/lib/private/legacy/app.php(149): OC_App::requireAppFile('encryption')
#19 /var/www/html/nextcloud/lib/private/legacy/app.php(124): OC_App::loadApp('encryption')
#20 /var/www/html/nextcloud/lib/private/Console/Application.php(104): OC_App::loadApps()
#21 /var/www/html/nextcloud/console.php(99): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#22 /var/www/html/nextcloud/occ(11): require_once('/var/www/html/n...')
#23 {main}
The table exists, but I get this ERROR 1932 (42S02): Table 'nextcloud516970.oc_filecache' doesn't exist in engine error.
MariaDB [nextcloud516970]> show tables;
| Tables_in_nextcloud516970 |
| oc_accounts |
| oc_activity |
| oc_activity_mq |
| oc_addressbookchanges |
| oc_addressbooks |
| oc_admin_sections |
| oc_admin_settings |
| oc_appconfig |
| oc_authtoken |
| oc_bruteforce_attempts |
| oc_calendarchanges |
| oc_calendarobjects |
| oc_calendarobjects_props |
| oc_calendars |
| oc_calendarsubscriptions |
| oc_cards |
| oc_cards_properties |
| oc_comments |
| oc_comments_read_markers |
| oc_credentials |
| oc_dav_shares |
| oc_federated_reshares |
| oc_file_locks |
| oc_filecache |
| oc_files_trash |
| oc_flow_checks |
| oc_flow_operations |
| oc_group_admin |
| oc_group_user |
| oc_groups |
| oc_jobs |
| oc_mimetypes |
| oc_mounts |
| oc_notifications |
| oc_notifications_pushtokens |
| oc_oauth2_access_tokens |
| oc_oauth2_clients |
| oc_preferences |
| oc_privatedata |
| oc_properties |
| oc_schedulingobjects |
| oc_share |
| oc_share_external |
| oc_storages |
| oc_systemtag |
| oc_systemtag_group |
| oc_systemtag_object_mapping |
| oc_trusted_servers |
| oc_twofactor_backupcodes |
| oc_twofactor_totp_secrets |
| oc_users |
| oc_vcategory |
| oc_vcategory_to_object |
53 rows in set (0.00 sec)
MariaDB [nextcloud516970]> select * from oc_filecache;
Any ideas? Can I just drop this table and rebuild it? How?
