November maintenance updates for Nextcloud Hub 7, 8 and 9
Originally published at: November maintenance updates for Nextcloud Hub 7, 8 and 9 - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 7, 8 or 9, we strongly recommend you to update to version 28.0.12, 29.0.9 or 30.0.2 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
The updates include a number of important bug fixes and performance optimization, as well as other improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Updates are available for:
  • Nextcloud Hub 7 (version 28.0.12)
  • Nextcloud Hub 8 (version 29.0.9)
  • Nextcloud Hub 9 (version 30.0.2)
Nextcloud Hub 9 is our latest and greatest! 🚀
Nextcloud Hub 9 lets you stay connected like never before: federated calls, auto-magic with Nextcloud Flow, collaboration through a new medium with Nextloud Whiteboard, a big design redo and much more!
What’s new in Nextcloud Hub 9:
  • Federation: Edit documents and have video calls with users from other Nextcloud servers!
  • Automate and digitalize enterprise processes
  • Brand new design improvements
  • New Whiteboard app
  • AI reminders & summaries in Mail
  • PDF templates and form API
  • Chat UI for Nextcloud Assistant
Nextcloud - Get Nextcloud Hub 9
Get Nextcloud Hub 9
Download and install Nextcloud Hub 9 here!
Get Hub 9
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
