Notify_push randomly (not)working
    • 32
    • Debian 13
    • Nginx Proxy Manager
    • Docker compose
My new setup of notify_push seems to be randomly working/not working.
Can anybody poke me in to the right direction?
How should I debug this? What can be the cause?
I’m getting these responses (randomly not working - 🗴 push server can’t connect to the Nextcloud server):
root@data:/root# /usr/bin/docker exec -u www-data data-app-1 php -d memory_limit=-1 occ notify_push:self-test
✓ redis is configured
✓ push server is receiving redis messages
✓ push server can load mount info from database
🗴 push server can't connect to the Nextcloud server
✓ push server can connect to the Nextcloud server
✓ push server is a trusted proxy
✓ push server is running the same version as the app
I’m using this docker-compose.yml:
services:
  notify_push:
    image: nextcloud
    restart: unless-stopped
    depends_on:
      - app
    environment:
      - NEXTCLOUD_URL=http://app
    ports:
    - 7867:7867
    entrypoint: /var/www/html/custom_apps/notify_push/bin/x86_64/notify_push /var/www/html/config/config.php
    volumes:
    - /mnt/data:/var/www/html/data
    - html:/var/www/html
  app:
    image: nextcloud
    volumes:
    ports:
    - 80:80
    environment:
    - APACHE_DISABLE_REWRITE_IP=1
    - NEXTCLOUD_TRUSTED_DOMAINS=data.localdomain data.ucl.cas.cz app
    - TRUSTED_PROXIES=172.16.0.0/12
    depends_on:
    - db
    - onlyoffice
    - redis
Metrics of notify_push:
root@data:/root# /usr/bin/docker exec -u www-data data-app-1 php -d memory_limit=-1 occ notify_push:metrics
Active connection count: 2
Active user count: 2
Total connection count: 2
Total database query count: 1
Events received: 7
Messages sent: 0
Messages sent (file): 0
Messages sent (notification): 0
Messages sent (activity): 0
Messages sent (custom): 0
Setup (randomly not working - 🗴 push server can’t connect to the Nextcloud server):
root@data:/root# /usr/bin/docker exec -u www-data data-app-1 php -d memory_limit=-1 occ notify_push:setup https://data.ucl.cas.cz/push
  configuration saved
config.php (without mail, db and redis…):
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'trusted_proxies' =>
    0 => '172.16.0.0/12',
    0 => 'localhost',
    1 => 'data.localdomain',
    2 => 'data.ucl.cas.cz',
    3 => 'app',
  'version' => '32.0.0.13',
  'overwrite.cli.url' => 'https://data.ucl.cas.cz',
  'instanceid' => 'xxx',
  'theme' => '',
  'default_phone_region' => 'CZ',
  'loglevel' => 0,
  'overwritehost' => 'data.ucl.cas.cz',
  'data-fingerprint' => 'xxx',
  'auth.webauthn.enabled' => false,
  'defaultapp' => '',
Some logs of notify_push:
[2025-10-15 19:13:34.495757 +00:00] DEBUG [hyper::proto::h1::conn] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/conn.rs:283: read eof
[2025-10-15 19:13:34.498120 +00:00] DEBUG [hyper::proto::h1::io] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/io.rs:211: parsed 10 headers
[2025-10-15 19:13:34.498127 +00:00] DEBUG [hyper::proto::h1::conn] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/conn.rs:224: incoming body is empty
[2025-10-15 19:13:34.498168 +00:00] DEBUG [hyper_util::client::legacy::pool] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-util-0.1.16-8d9b05277c7e8da2c93a568989bb6207bef0112e8d17df7a6eda4a3cf143bc5e/src/client/legacy/pool.rs:269: reuse idle connection for ("http", app)
[2025-10-15 19:13:34.524619 +00:00] DEBUG [hyper_util::client::legacy::pool] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-util-0.1.16-8d9b05277c7e8da2c93a568989bb6207bef0112e8d17df7a6eda4a3cf143bc5e/src/client/legacy/pool.rs:395: pooling idle connection for ("http", app)
[2025-10-15 19:13:34.524689 +00:00] DEBUG [notify_push] /build/source/src/lib.rs:282: got remote test cookie 685031571
[2025-10-15 19:13:34.524802 +00:00] DEBUG [hyper::proto::h1::io] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/io.rs:330: flushed 125 bytes
[2025-10-15 19:13:34.524946 +00:00] DEBUG [hyper::proto::h1::conn] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/conn.rs:283: read eof
[2025-10-15 19:13:34.527585 +00:00] DEBUG [hyper::proto::h1::io] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/io.rs:211: parsed 10 headers
[2025-10-15 19:13:34.527594 +00:00] DEBUG [hyper::proto::h1::conn] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/conn.rs:224: incoming body is empty
[2025-10-15 19:13:34.527649 +00:00] DEBUG [hyper_util::client::legacy::pool] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-util-0.1.16-8d9b05277c7e8da2c93a568989bb6207bef0112e8d17df7a6eda4a3cf143bc5e/src/client/legacy/pool.rs:269: reuse idle connection for ("http", app)
[2025-10-15 19:13:34.553780 +00:00] DEBUG [hyper_util::client::legacy::pool] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-util-0.1.16-8d9b05277c7e8da2c93a568989bb6207bef0112e8d17df7a6eda4a3cf143bc5e/src/client/legacy/pool.rs:395: pooling idle connection for ("http", app)
[2025-10-15 19:13:34.553859 +00:00] DEBUG [notify_push] /build/source/src/lib.rs:322: got remote 1.2.3.4 when trying to set remote 1.2.3.4
[2025-10-15 19:13:34.553924 +00:00] DEBUG [hyper::proto::h1::io] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/io.rs:330: flushed 123 bytes
[2025-10-15 19:13:34.554086 +00:00] DEBUG [hyper::proto::h1::conn] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/conn.rs:283: read eof
[2025-10-15 19:13:34.557040 +00:00] DEBUG [hyper::proto::h1::io] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/io.rs:211: parsed 11 headers
[2025-10-15 19:13:34.557047 +00:00] DEBUG [hyper::proto::h1::conn] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/conn.rs:224: incoming body is empty
[2025-10-15 19:13:34.557595 +00:00] DEBUG [hyper::proto::h1::io] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/io.rs:330: flushed 119 bytes
[2025-10-15 19:13:34.557718 +00:00] DEBUG [hyper::proto::h1::conn] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/conn.rs:283: read eof
Any other information’s needed?
https://data.ucl.cas.cz/index.php/apps/notify_push/test/version
→ Internal Server Error
Logs:
DomainException No responder registered for format xhtml+xml!
{"reqId":"Tvw0SnGMNA6ldWA8AnMB","level":3,"time":"2025-10-16T05:12:11+00:00","remoteAddr":"172.16.0.143","user":"spravce","app":"index","method":"GET","url":"/index.php/apps/notify_push/test/version","message":"No responder registered for format xhtml+xml!","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:143.0) Gecko/20100101 Firefox/143.0","version":"32.0.0.13","exception":{"Exception":"DomainException","Message":"No responder registered for format xhtml+xml!","Code":0,"Trace":[{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":216,"function":"buildResponse","class":"OCP\\AppFramework\\Controller","type":"->","args":[null,"xhtml+xml"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\NotifyPush\\Controller\\TestController"},"version"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\NotifyPush\\Controller\\TestController"},"version"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\NotifyPush\\Controller\\TestController","version",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"notify_push.test.version"}]},{"file":"/var/www/html/lib/base.php","line":1061,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/notify_push/test/version"]},{"file":"/var/www/html/index.php","line":25,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/public/AppFramework/Controller.php","Line":139,"message":"No responder registered for format xhtml+xml!","exception":[],"CustomMessage":"No responder registered for format xhtml+xml!"},"id":"68f07ead3138a"}
https://data.ucl.cas.cz/index.php/apps/notify_push/test/remote
→ OK
https://data.ucl.cas.cz/index.php/apps/notify_push/test/cookie
Logs:
{"reqId":"7AbRX1HgNS2pAZUQ3eSB","level":3,"time":"2025-10-16T05:19:43+00:00","remoteAddr":"172.16.0.143","user":"spravce","app":"index","method":"GET","url":"/index.php/apps/notify_push/test/cookie","message":"No responder registered for format xhtml+xml!","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:143.0) Gecko/20100101 Firefox/143.0","version":"32.0.0.13","exception":{"Exception":"DomainException","Message":"No responder registered for format xhtml+xml!","Code":0,"Trace":[{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":216,"function":"buildResponse","class":"OCP\\AppFramework\\Controller","type":"->","args":[{"__class__":"OCP\\AppFramework\\Http\\DataResponse"},"xhtml+xml"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\NotifyPush\\Controller\\TestController"},"cookie"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\NotifyPush\\Controller\\TestController"},"cookie"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\NotifyPush\\Controller\\TestController","cookie",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"notify_push.test.cookie"}]},{"file":"/var/www/html/lib/base.php","line":1061,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/notify_push/test/cookie"]},{"file":"/var/www/html/index.php","line":25,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/public/AppFramework/Controller.php","Line":139,"message":"No responder registered for format xhtml+xml!","exception":[],"CustomMessage":"No responder registered for format xhtml+xml!"},"id":"68f08070e615b"}
The error logs could be explained by:
But it still doesn’t explain why some of the URLs above are giving an error.
Hi Antonin,
The issue happens because the notify_push container is using the wrong internal URL to reach your Nextcloud app.
In your docker-compose file, change the line to use your public HTTPS domain instead of the internal service name:
NEXTCLOUD_URL=https://data.ucl.cas.cz
After that, restart your containers and run the notify_push setup again.
Also, make sure your reverse proxy is forwarding the correct headers:
  • Host
  • X-Forwarded-For
  • X-Forwarded-Proto (set to “https”)
The “xhtml+xml” error you see is a known issue in Nextcloud 32, it doesn’t affect functionality and can be safely ignored.
This should stabilize your notify_push connection and stop the random failures.
Hello @Antonin_Chadima,
welcome to the Nextcloud community! :handshake:
In the past I hit strange issues when I had multiple (Nextcloud) apps connected to the same reverse proxy network. For this reason multiple app containers existed and DNS resolution was random as notify_push was connecting to a random “app”.. As suggested by marvin use you public DNS name or ensure unique DNS
Thank you a lot.
using:
environment:
  - NEXTCLOUD_URL=https://data.ucl.cas.cz
leads to exactly the same results. 3 times ERROR + 1 time OK etc. randomly…
the reverse proxy headers are set OK
How to debug this issue?
should i try to ping from the notify_push container to app container or to data.ucl.cas.cz?
and try wget/curl from notify_push? capture network packets?
ping ok from inside container notify_push to app and data.ucl.cas.cz
curl not working (?)
wget 100% ok to http://app and https://data.ucl.cas.cz
should I try some specific address used by the notify_push test?
and/or trying some headers?
any idea?
i tried the test client
antoninchadima@penguin:~/Downloads$ ./test_client-x86_64-unknown-linux-musl https://data.ucl.cas.cz chadima NA24.pw999
[2025-10-16 12:40:59.538173 +02:00] INFO [test_client] test_client/src/main.rs:39: Found push server at wss://data.ucl.cas.cz/push/ws
[2025-10-16 12:40:59.967311 +02:00] INFO [test_client] test_client/src/main.rs:73: Authenticated
stuck there and after a while:
Error:   × IO error: Connection reset by peer (os error 104)
  ╰─▶ Connection reset by peer (os error 104)
logs:
[2025-10-16 10:41:00.609055 +00:00] DEBUG [hyper::proto::h1::io] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/io.rs:211: parsed 9 headers
[2025-10-16 10:41:00.609089 +00:00] DEBUG [hyper::proto::h1::conn] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/conn.rs:224: incoming body is empty
[2025-10-16 10:41:00.609122 +00:00] DEBUG [notify_push] /build/source/src/lib.rs:262: new websocket connection from Some(172.16.0.1)
[2025-10-16 10:41:00.609211 +00:00] DEBUG [hyper::proto::h1::io] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-0.14.32-41dfc780fdec9373c01bae43289ea34c972e40ee3c9f6b3c8801a35f35586ce7/src/proto/h1/io.rs:330: flushed 166 bytes
[2025-10-16 10:41:00.672617 +00:00] DEBUG [notify_push::nc] /build/source/src/nc.rs:35: Verifying credentials for chadima
[2025-10-16 10:41:00.672665 +00:00] DEBUG [reqwest::connect] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/reqwest-0.12.22-cbc931937e6ca3a06e3b6c0aa7841849b160a90351d6ab467a8b9b9959767531/src/connect.rs:789: starting new connection: https://data.ucl.cas.cz/
[2025-10-16 10:41:00.673376 +00:00] DEBUG [hyper_util::client::legacy::connect::http] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-util-0.1.16-8d9b05277c7e8da2c93a568989bb6207bef0112e8d17df7a6eda4a3cf143bc5e/src/client/legacy/connect/http.rs:768: connecting to 147.231.80.37:443
[2025-10-16 10:41:00.673653 +00:00] DEBUG [hyper_util::client::legacy::connect::http] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-util-0.1.16-8d9b05277c7e8da2c93a568989bb6207bef0112e8d17df7a6eda4a3cf143bc5e/src/client/legacy/connect/http.rs:771: connected to 147.231.80.37:443
[2025-10-16 10:41:00.897814 +00:00] DEBUG [hyper_util::client::legacy::pool] /nix/store/0znp1v8mdyfkxabl7l7b8vqdxyfpsyc0-crates-io-dependencies/hyper-util-0.1.16-8d9b05277c7e8da2c93a568989bb6207bef0112e8d17df7a6eda4a3cf143bc5e/src/client/legacy/pool.rs:395: pooling idle connection for ("https", data.ucl.cas.cz)
[2025-10-16 10:41:00.897896 +00:00] INFO [notify_push::connection] /build/source/src/connection.rs:111: new websocket authenticated as chadima
Hi Antonin,
This issue happens because of how the push server connects through HTTPS inside Docker. You can fix it completely with these steps:
  1. In your docker-compose file, set
    (Use the internal container name, not the public HTTPS domain.)
  2. In config.php, make sure you have:
    ‘overwritehost’ => ‘data.ucl.cas.cz’,
    ‘overwriteprotocol’ => ‘https’,
    ‘trusted_proxies’ => [‘172.16.0.0/12’],
    ‘trusted_domains’ => [‘data.ucl.cas.cz’, ‘app’, ‘localhost’],
  3. In Nginx Proxy Manager, open the proxy for data.ucl.cas.cz:
    • Disable HTTP/2
    • Add these under “Advanced”:
      proxy_read_timeout 3600;
      proxy_send_timeout 3600;
      proxy_set_header Connection “upgrade”;
      proxy_set_header X-Forwarded-Proto https;
  4. Restart both containers (app and notify_push), then run
After this, the push server should connect consistently without random errors.
Hello, could you fix this ? I am struggling with the same issue, except I am not using a docker install but manual install, and apache2 for the reverse proxy.
The self-test also randomly works. The version and cookie pages also lead to internal server error, and same error in the logs
I am running the notify_push server as a systemd service
[Unit]
After=network.target mariadb.service apache2.service redis.service
Description = Push daemon for Nextcloud clients
Documentation = https://github.com/nextcloud/notify_push
[Service]
Environment = PORT=7867
Environment = NEXTCLOUD_URL=https://cloud.mydomain.com
ExecStart = /var/www/html/nextcloud/apps/notify_push/bin/x86_64/notify_push /var/www/html/nextcloud/config/config.php
Type = notify
User = www-data
Restart = always
RestartSec = 60
[Install]
WantedBy = multi-user.target
In config.php in trusted_proxies I have:
0 => ‘my public ipv4’,
1 => ‘my public ipv6’,
2 => ‘127.0.0.1’,
3 => ‘::1’,
In apache vhost I have this:
ProxyPass /push/ws ws://127.0.0.1:7867/ws ProxyPass /push/ http://127.0.0.1:7867/
ProxyPassReverse /push/ http://127.0.0.1:7867/ RequestHeader set Host %{HTTP_HOST}s
RequestHeader set X-Forwarded-For %{REMOTE_ADDR}s
RequestHeader set X-Forwarded-Proto "https"
I’m a bit stuck…
Edit: apart from these errors, I think the app works
I’m in the same situation as you, and I think it works as well… I created a .txt through the web interface, it got synced right away to my PC, all while running the test_client binary, which displayed when a change occured…
after a while and some updates, still the same situation
no news? howto debug?
The desktop app seems to be working, but sometimes there are new random synchronization errors amongst our 500 users.
