example
longer
example
here
Nextcloud version (eg, 20.0.5): 27.1.4
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.52
PHP version (eg, 7.4): 8.1.2
PI have a problem with Notify_push, I can’t install it and link it to Nextcloud in any way. I connected everything according to the instructions, installed Redis, connected everything together. I decided to do a test, found on github how to do it, but during the test ./test_client http://192.168.1.123 test test1, when performing the test, it writes to me what is in the screenshot. The certificate is self-signed and trusted, there is no red error when going to the site. But still no notifications are coming. Maybe you’ve solved it and you know what you can do, if so, please help
- ./test_client http://192.168.1.123 test test1,
[internet_connection_check] Ошибка: GuzzleHttp\Exception\ConnectException: cURL error 28: Operation timed out after 30001 milliseconds with 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://nextcloud.com at <<closure>>
0. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php line 158
GuzzleHttp\Handler\CurlFactory::createRejection("*** sensitive parameters replaced ***")
1. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php line 110
GuzzleHttp\Handler\CurlFactory::finishError()
2. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php line 47
GuzzleHttp\Handler\CurlFactory::finish()
3. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php line 137
GuzzleHttp\Handler\CurlHandler->__invoke()
4. /var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php line 154
GuzzleHttp\Middleware::GuzzleHttp\{closure}("*** sensitive parameters replaced ***")
5. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php line 35
OC\Http\Client\DnsPinMiddleware->OC\Http\Client\{closure}("*** sensitive parameters replaced ***")
6. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php line 31
GuzzleHttp\PrepareBodyMiddleware->__invoke()
7. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php line 71
8. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php line 107
GuzzleHttp\RedirectMiddleware->__invoke()
9. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php line 73
GuzzleHttp\RedirectMiddleware->checkRedirect()
10. /var/www/nextcloud/3rdparty/guzzlehttp/promises/src/FulfilledPromise.php line 41
GuzzleHttp\RedirectMiddleware->GuzzleHttp\{closure}("*** sensitive parameters replaced ***")
11. /var/www/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php line 48
GuzzleHttp\Promise\FulfilledPromise::GuzzleHttp\Promise\{closure}("*** sensitive parameters replaced ***")
12. /var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php line 248
GuzzleHttp\Promise\TaskQueue->run()
13. /var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php line 224
GuzzleHttp\Promise\Promise->invokeWaitFn()
14. /var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php line 269
GuzzleHttp\Promise\Promise->waitIfPending()
15. /var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php line 226
GuzzleHttp\Promise\Promise->invokeWaitList()
16. /var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php line 62
17. /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php line 187
GuzzleHttp\Promise\Promise->wait()
18. /var/www/nextcloud/lib/private/Http/Client/Client.php line 230
GuzzleHttp\Client->request()
19. /var/www/nextcloud/apps/settings/lib/Controller/CheckSetupController.php line 224
OC\Http\Client\Client->get()
20. /var/www/nextcloud/apps/settings/lib/Controller/CheckSetupController.php line 206
OCA\Settings\Controller\CheckSetupController->isSiteReachable()
21. /var/www/nextcloud/apps/settings/lib/Controller/CheckSetupController.php line 921
OCA\Settings\Controller\CheckSetupController->hasInternetConnectivityProblems()
22. /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 230
OCA\Settings\Controller\CheckSetupController->check()
23. /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 137
24. /var/www/nextcloud/lib/private/AppFramework/App.php line 183
25. /var/www/nextcloud/lib/private/Route/Router.php line 315
OC\AppFramework\App::main()
26. /var/www/nextcloud/lib/base.php line 1068
OC\Route\Router->match()
27. /var/www/nextcloud/index.php line 36
OC::handleRequest()
GET /index.php/settings/ajax/checksetup
from 192.168.1.123 by cloud at 2023-12-07T08:21:29+00:00
[PHP] Ошибка: RedisException: No such file or directory at /var/www/nextcloud/lib/private/RedisFactory.php#137
GET /ocs/v2.php/apps/dashboard/api/v2/widget-items?widgets%5B%5D=activity
from 192.168.1.33 at 2023-12-07T08:15:09+00:00
GNU nano 6.2 config.php
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => '192.168.1.123',
1 => 'cloud',
'datadirectory' => '/media/cloud/Nextcloud/data/',
'version' => '27.1.4.1',
'overwrite.cli.url' => 'http://192.168.1.123',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'cloud',
'dbpassword' => '2Re5W34',
'trashbin_retention_obligation' => 'auto, 7',
'updater.secret' => '$2y$10$7ljEGfe/hKum0xww1qih0.xoxpyK814tSkljit9o8Mrwly5ok.oge',
'theme' => '',
'loglevel' => 2,
'trusted_proxies' =>
1 => 'cloud',
2 => '127.0.0.1',
3 => '::1',
'memcache.local' => '\OC\Memcache\Redis',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
access.log error.log.2.gz other_vhosts_access.log.12.gz
access.log.1 error.log.3.gz other_vhosts_access.log.13.gz
access.log.2.gz error.log.4.gz other_vhosts_access.log.14.gz
access.log.3.gz error.log.5.gz other_vhosts_access.log.2.gz
access.log.4.gz error.log.6.gz other_vhosts_access.log.3.gz
error.log error.log.7.gz other_vhosts_access.log.4.gz
error.log.1 error.log.8.gz other_vhosts_access.log.5.gz
error.log.10.gz error.log.9.gz other_vhosts_access.log.6.gz
error.log.11.gz other_vhosts_access.log other_vhosts_access.log.7.gz
error.log.12.gz other_vhosts_access.log.1 other_vhosts_access.log.8.gz
error.log.13.gz other_vhosts_access.log.10.gz other_vhosts_access.log.9.gz
error.log.14.gz other_vhosts_access.log.11.gz
PASTE HERE
