Hi.
I get every time when the cronjob runs an error:
{"reqId":"vgD5pBTiLbgNR3mKOlpP","level":3,"time":"2024-06-25T13:10:02+00:00","remoteAddr":"","user":"--","app":"documentserver_community","method":"","url":"--","message":"Error while applying changes for document 612334112","userAgent":"--","version":"28.0.4.1","exception":{"Exception":"OCP\\Files\\NotFoundException","Message":"/appdata_ocmt3glcvpnh/documentserver_community/doc_612334112/owner","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Files/Node/Folder.php","line":135,"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SimpleFS/SimpleFolder.php","line":75,"function":"get","class":"OC\\Files\\Node\\Folder","type":"->"},{"file":"/var/www/nextcloud/apps/documentserver_community/lib/Document/DocumentStore.php","line":137,"function":"getFile","class":"OC\\Files\\SimpleFS\\SimpleFolder","type":"->"},{"file":"/var/www/nextcloud/apps/documentserver_community/lib/Document/SaveHandler.php","line":58,"function":"saveChanges","class":"OCA\\DocumentServer\\Document\\DocumentStore","type":"->"},{"file":"/var/www/nextcloud/apps/documentserver_community/lib/BackgroundJob/Cleanup.php","line":71,"function":"flushChanges","class":"OCA\\DocumentServer\\Document\\SaveHandler","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":81,"function":"run","class":"OCA\\DocumentServer\\BackgroundJob\\Cleanup","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":67,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\Job","type":"->"}],"File":"/var/www/nextcloud/lib/private/Files/Node/Root.php","Line":207,"message":"Error while applying changes for document 612334112","CustomMessage":"Error while applying changes for document 612334112"},"id":"667ac1ad5dd28"}
The Folder /appdata_ocmt3glcvpnh/documentserver_community/doc_612334112/ is completly empty.
Infos:
- Nextcloud 28.0.4
- Community Document Server 0.1.17
- PHP 8.1.28
- mysql-server 8.0.36-1ubuntu20.04
*Ubuntu 22.04.4 LTS
Best regards,
Cookie
