Not yet another .ocdata / cron issue!
Nextcloud 24.0.1
ubuntu 20.04.4
php 7.4 php-fpm
nginx 1.21.6
apache2 2.4.53
hestia panel 1.5.15
The issue you are facing: in Settings/Overview
  • It was not possible to execute the cron job via CLI. The following technical errors have appeared:
    • Votre répertoire des données n’est pas valide. Assurez-vous que le répertoire de données contient un fichier “.ocdata” à sa racine.
  • Last background job execution ran 4 days ago. Something seems wrong. Check the background job settings :arrow_upper_right:.
output of your config.php file:
  'instanceid' => 'oc...',
  'passwordsalt' => '...',
  'secret' => '...',
    0 => 'lab.land.com',
  'datadirectory' => '/home/httpuser/web/lab.land.com/public_html/data',
  'version' => '24.0.1.1',
  'overwrite.cli.url' => 'https://lab.land.com',
  'dbname' => 'prod_bdd',
  'dbhost' => 'localhost',
  'dbtableprefix' => 'cc_',
  'dbuser' => 'prod_manager',
  'dbpassword' => '...',
  'app_install_overwrite' =>
    0 => 'browser_warning',
    1 => 'defaultgroup',
    2 => 'nextbackup',
    3 => 'admin_notifications',
    4 => 'files_trackdownloads',
    5 => 'external',
    6 => 'files_texteditor',
  'enable_previews' => false,
  'theme' => '',
  'default_phone_region' => 'FR',
  'loglevel' => 1,
  'mail_smtpmode' => 'smtp',
  'mail_smtpsecure' => 'tls',
  'mail_from_address' => 'lab',
  'mail_domain' => 'land.com',
  'mail_smtpauth' => 1,
  'mail_smtphost' => 'mail.land.com',
  'mail_smtpport' => '587',
  'mail_smtpname' => 'lab@land.com',
  'mail_smtppassword' => '...',
I can’t locate these, can you precise please ?
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T23:19:36+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T23:19:35+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T23:19:35+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T23:18:14+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T23:18:14+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T23:18:13+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T22:32:31+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T22:32:31+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T22:32:30+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T22:27:38+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T22:27:38+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T22:27:38+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T22:08:13+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T22:08:13+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T22:08:13+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:54:16+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:54:16+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:54:16+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:49:39+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:49:39+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:49:39+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:48:27+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:48:27+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:48:27+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:48:03+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:48:03+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:48:02+0200
Info files_lock [notice] unlocking file – {fileLock:{}} 2022-06-08T21:46:55+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:46:10+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:46:10+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:46:09+0200
Info no app in context Symfony\Component\Routing\Exception\RouteNotFoundException: Unable to generate a URL for the named route settings.Help.help as such route does not exist. 2022-06-08T21:39:03+0200
Info no app in context Symfony\Component\Routing\Exception\RouteNotFoundException: Unable to generate a URL for the named route theming.Theming.getImage as such route does not exist. 2022-06-08T21:39:03+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:34:52+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:34:51+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:34:51+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:34:03+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:34:03+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:34:02+0200
Info no app in context Symfony\Component\Routing\Exception\RouteNotFoundException: Unable to generate a URL for the named route settings.Help.help as such route does not exist. 2022-06-08T21:33:54+0200
Info no app in context Symfony\Component\Routing\Exception\RouteNotFoundException: Unable to generate a URL for the named route theming.Theming.getImage as such route does not exist. 2022-06-08T21:33:54+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:33:15+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_INDEXES: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:33:15+0200
Info no app in context Deprecated event type for OCP\IDBConnection::CHECK_MISSING_PRIMARY_KEYS: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:33:14+0200
Info files_lock [notice] locking file – {fileLock:{id:0,uri:,userId:text,displayName:null,fileId:4638,token:files_lock/440f6f6e-8445-46f5-be5b-e85acee1d0a6,eta:-1,creation:1654715842,type:1}} 2022-06-08T21:17:22+0200
Info no app in context Deprecated event type for OCA\Files::loadAdditionalScripts: Symfony\Component\EventDispatcher\GenericEvent is used 2022-06-08T21:16:49+0200
I've tried many different settings in the cron job. For now it is:
php -f /web/lab.land.com/public_html/next2024/cron.php
.ocdata is in the data folder, every folder is owned by httpuser
    0 -rw-r--r--  1 prod prod        0 May 30 18:10 .ocdata
Is the cron job running as the unix user of the webserver?
i’m not sure about that
the cron job is set in hestia cp
but a command like
$ sudo crontab -u hestia user -l
gives a proper answer
I can’t find out what should be the correct command for the cron though, amongst many articles …
php
php-cli
-f ~/web/collab.koraland.net/public_html/next2024/cron.php
-f /web/collab.koraland.net/public_html/next2024/cron.php
add apc.enable_cli=1 in /etc/php/7.4/mods-available/apcu.ini
or just add it at the end of the cron command
what if the cron problem comes from the .ocadata problem in the 1st place?
hi guys
so? any offer amongst your own cron settings?
