Not able use occ commands no permission
Nextcloud version (eg, 20.0.5): 28.0.2
Operating system and version (eg, Ubuntu 20.04): 22.04
PHP version (eg, 7.4): 8.1
I tried to using a occ command in the directory of nextcloud. I got this error and now I don’t know what to do:
The output from the console nextcloud/:
PHP Warning:  require_once(/root/nextcloud/nextcloud/console.php): Failed to open stream: Permission denied in /root/nextcloud/nextcloud/occ on line 11
PHP Fatal error:  Uncaught Error: Failed opening required '/root/nextcloud/nextcloud/console.php' (include_path='.:/usr/share/php') in /root/nextcloud/nextcloud/occ:11
Stack trace:
#0 {main}
  thrown in /root/nextcloud/nextcloud/occ on line 11
Do you really have installed Nextcloud in /root/nextcloud?
What occ command did you execute?
I installed it in /root/nextcloud/nextcloud with docker-compose. Thats why I tried the command in this directory.
Hmmm - maybe you might run into truble, because the /root folder only has permissions to user “root”.
I am not sure, whether it is a general requirement:
Nextcloud requires permissions to user www-data, so it in normal cases will be installed f.e. in /var/www/nextcloud
btw.: You only did answer my 1st question.
I used the command to activate the maintenace mode.
Please post exactly the whole command, you tried to execute.
sudo -u www-data php occ maintenance:mode --on
That’s part of your problem. If you’re using Docker, the command must be ran in the container not on your host.
Please see the documentation: GitHub - nextcloud/docker: ⛴ Docker image of Nextcloud
